Restoring Maps Missing or Deleted Off an Automotive Device
If the map information page on an automotive device is inaccessible (greyed out), blank, or only shows the word Update Maps without any map information, the map file may be missing or deleted from your device. For steps to view the map information page, refer to your device's owners' manual.
A missing or deleted map may also be indicated by a missing gmapprom.img file on your device drive or SD card, if inserted. It is not recommended to manually move or delete this file.
If a memory card was used to update the device previously, it may be necessary to format the inserted memory card.
  • To format the card on the following devices, see Formatting the Memory Card on an Automotive Device.
    • Camper 890 caravan and motorhome sat nav | RV 890 RV navigator
    • Camper 895 caravan and motorhome sat nav | RV 895 RV navigator
    • Camper 1090 caravan and motorhome sat nav |RV 1090 RV navigator
    • Camper 1095 caravan and motorhome sat nav |RV 1095 RV navigator
    • dēzl™ LGV800 | dēzl™ OTR800 GPS navigators
    • dēzl™ LGV810 | dēzl™ OTR810 GPS navigators
    • dēzl™ LGV1000 | dēzl™ OTR1000 GPS navigators
    • dēzl™ LGV1010 | dēzl™ OTR1010 GPS navigators
  • To format the card with all other devices, see Formatting a microSD/SD Memory Card.
To Resolve this Issue:
Ensure Garmin Express is up-to-date with the steps found in Updating the Garmin Express™ Application Software.
If Garmin Express fails to install that map successfully, you can resolve that with the instructions listed in Garmin Express not Working for Updates and Downloads.
