User Data Limitations of the Oregon 700 series
When sending or creating files for an Oregon® 700 series handheld, keep in mind the following limitations:
  • 2,000 GPX files
  • 10,000 waypoints
  • No limit on geocaches (outside of max number of GPX  files supported and memory available)
  • 250 routes, 250 points per route; 50 points turn-by-turn routing
  • 250 saved tracks
  • 2,000 archive tracks
  • 20,000 points per track
  • 500 custom map tiles
  • 250 BirdsEye Imagery files
  • Mapping segments 15,0001
Each GPX file can contain a mixture of waypoints, geocaches, routes and tracks. If the GPX file containing a waypoint or geocache is deleted, the waypoint will no longer be available on the device.
When utilizing routes, only 50 points can be used for turn-by-turn navigation on roads or trails.
1 See Related for more information on map segments.
Sumber terkait
