Yellow Light on Pro 550 Plus
If the Pro 550 Plus dog training handheld experiences interference from another transmitter, the LED flashes yellow when you press a training key. If this occurs often, re-pairing a dog collar device to the color it is already assigned to may resolve the problem. Re-pairing changes the frequency used by the handheld device to communicate with the dog collar device.
Pairing a Dog Collar Device with the Handheld Device:
NOTE: If your handheld device and dog collar device were included in the same package, the devices are already paired.
- If the dog collar device is on, turn off the dog collar device
- Hold the power key on the dog collar device until the dog collar device emits two series of beeps (about 2 seconds), and then release the power key. The status LED flashes green rapidly. You can now pair the dog collar device with a handheld device.
- On the handheld device, select a color with the toggle switch. The dog collar device will be assigned to this color.
- On the handheld device, turn the intensity dial to N.
- On the handheld device, select the tone key.
- On the handheld device, select the top training key.
- Follow the on-screen instructions. The Broadcast icon appears on the handheld device screen. The handheld device is ready to pair.
The handheld device vibrates and a check mark appears on the screen when the devices have paired successfully.
TIP: You must obtain GPS signals on both devices before the handheld device displays the dog collar device battery status, distance, and direction.
