Dual Voice Coil (DVC) Wiring Tutorial
With multi-driver sub systems, which often feature dual voice coils (DVC) on each driver, the level of wiring complexity can be enough to turn-off even the most adventurous of car audio do-it-yourselfers. Wiring Diagrams of several configurations for Dual Voice Coil (DVC) drivers have been compiled.
Please note that when wiring multiple drivers it is recommended that series connections between drivers be avoided at all costs. This does not include series connections made between voice coils on the same driver. For more information, please consult our Dual Voice Coil FAQs.
Additionally, if the user has an idea for a wiring configuration and is not seen here, the user should re-think its implementation (in other words, don’t do it). Likely the results will be less than optimal.
Note: Amplifier depicted is for reference only - check the capability of the amplifier before making any connections
One DVC driver with Voice Coils in Series
One Dual Voice Coil Speaker in Series
Connecting the two voice coils of the driver in series (+ to -) will result in the following impedances:
- Dual–8 Ohm Subwoofer: 16 Ohms
- Dual-6 Ohm Subwoofer: 12 Ohms
- Dual–4 Ohm Subwoofer: 8 Ohms
- Dual–2 Ohm Subwoofer: 4 Ohms
- Dual–1.5 Ohm Subwoofer: 3 Ohms
One DVC driver with Voice Coils in Parallel
One Dual Voice Coil Speaker in Parallel
Connecting the two voice coils of the driver in parallel (+ to +, - to -) will result in the following impedances:
- Dual–8 Ohm Subwoofer: 4 Ohms
- Dual-6 Ohm Subwoofer: 3 Ohms
- Dual–4 Ohm Subwoofer: 2 Ohms
- Dual–2 Ohm Subwoofer: 1 Ohm
- Dual–1.5 Ohm Subwoofer: 0.75 Ohm
Two DVC drivers with Voice Coils in Series / Parallel
Two Dual Voice Coil Speakers in Series / Parallel
Connecting the two voice coils of each driver in series (+ to -) and the drivers themselves in parallel (+ to +, etc.) will result in the following impedances:
- Dual–8 Ohm Subwoofers: 8 Ohms
- Dual-6 Ohm Subwoofers: 6 Ohms
- Dual–4 Ohm Subwoofers: 4 Ohms
- Dual–2 Ohm Subwoofers: 2 Ohms
- Dual–1.5 Ohm Subwoofers: 1.5 Ohms
Two DVC drivers with Voice Coils in Parallel / Parallel
Two Dual Voice Coil Speakers in Parallel / Parallel
Connecting the voice coils of each driver in parallel (+ to +, - to -) and the drivers themselves in parallel (+ to +, etc.) will result in the following impedances:
- Dual–8 Ohm Subwoofers: 2 Ohms
- Dual-6 Ohm Subwoofers: 1.5 Ohms
- Dual–4 Ohm Subwoofers: 1 Ohm
- Dual–2 Ohm Subwoofers: 0.5 Ohm
- Dual–1.5 Ohm Subwoofer: 0.38 Ohm
Three DVC drivers with Voice Coils in Series / Parallel
Three Dual Voice Coil Speakers in Series / Parallel
- Dual–8 Ohm Subwoofers: 5.33 Ohms
- Dual-6 Ohm Subwoofers: 4 Ohms
- Dual–4 Ohm Subwoofers: 2.67 Ohms
- Dual–2 Ohm Subwoofers: 1.33 Ohms
- Dual–1.5 Ohm Subwoofer: 1 Ohm
Three DVC drivers with Voice Coils in Parallel / Parallel
Three Dual Voice Coil Speakers in Parallel / Parallel
Connecting the two voice coils of each driver in parallel (+ to +, - to -) and the drivers themselves in parallel will result in the following impedances:
- Dual–8 Ohm Subwoofers: 1.33 Ohms
- Dual-6 Ohm Subwoofers: 1 Ohm
- Dual–4 Ohm Subwoofers: 0.67 Ohm
- Dual–2 Ohm Subwoofers: 0.33 Ohm
- Dual–1.5 Ohm Subwoofer: 0.25 Ohm
Four DVC drivers with Voice Coils in Series / Parallel
Four Dual Voice Coil Speakers in Series / Parallel
- Dual–8 Ohm Subwoofers: 4 Ohms
- Dual-6 Ohm Subwoofers: 3 Ohms
- Dual–4 Ohm Subwoofers: 2 Ohms
- Dual–2 Ohm Subwoofers: 1 Ohm
- Dual–1.5 Ohm Subwoofers: 0.75 Ohm
Four DVC drivers with Voice Coils in Parallel / Parallel
Four Dual Voice Coil Speakers in Parallel / Parallel
Connecting the two voice coils of each driver in parallel (+ to +, - to -) and the drivers themselves in parallel (+ to +, etc.) will result in the following impedances:
- Dual–8 Ohm Subwoofers: 1 Ohm
- Dual-6 Ohm Subwoofers: 0.75 Ohm
- Dual–4 Ohm Subwoofers: 0.5 Ohm
- Dual–2 Ohm Subwoofers: 0.25 Ohm
- Dual–1.5 Ohm Subwoofer: 0.19 Ohm
Five DVC drivers with Voice Coils in Series / Parallel
Five Dual Voice Coil Speakers in Series / Parallel
- Dual–8 Ohm Subwoofers: 3.2 Ohms
- Dual-6 Ohm Subwoofers: 2.4 Ohms
- Dual–4 Ohm Subwoofers: 1.6 Ohms
- Dual–2 Ohm Subwoofers: 0.8 Ohm
- Dual–1.5 Ohm Subwoofer: 0.6 Ohm
Five DVC drivers with Voice Coils in Parallel / Parallel
Five Dual Voice Coil Speakers in Parallel / Parallel
- Dual–8 Ohm Subwoofers: 0.8 Ohm
- Dual-6 Ohm Subwoofers: 0.6 Ohm
- Dual–4 Ohm Subwoofers: 0.4 Ohm
- Dual–2 Ohm Subwoofers: 0.2 Ohm
- Dual–1.5 Ohm Subwoofer: 0.15 Ohm
Six DVC drivers with Voice Coils in Series / Parallel
Six Dual Voice Coil Speakers in Series / Parallel
- Dual–8 Ohm Subwoofers: 2.67 Ohms
- Dual-6 Ohm Subwoofers: 2 Ohms
- Dual–4 Ohm Subwoofers: 1.3 Ohms
- Dual–2 Ohm Subwoofers: 0.7 Ohm
- Dual–1.5 Ohm Subwoofer: 0.5 Ohm
Six DVC drivers with Voice Coils in Parallel / Parallel
Six Dual Voice Coil Speakers in Parallel / Parallel
- Dual–8 Ohm Subwoofers: 0.67 Ohm
- Dual-6 Ohm Subwoofers: 0.5 Ohm
- Dual–4 Ohm Subwoofers: 0.33 Ohm
- Dual–2 Ohm Subwoofers: 0.167 Ohm
- Dual–1.5 Ohm Subwoofer: 0.125 Ohm
