EmpirBus Part Numbers and Specifications
Garmin Part NumberEmpirBus™ Part NumberSpecifications
Switching Modules
DC Modules
010-02219-02201010212v, 8 Outputs, 4 High Power Outputs, 2 Common Outputs, 16 Inputs
010-02219-03201010312v, 12 Outputs, 4 High Power Outputs, 2 Common Outputs, 16 Inputs
010-02219-04201010412v, 12 Outputs, 4 High Power Outputs, 2 Common Outputs , 4 Negative Outputs, 16 Inputs
010-02219-05201010512v, 12 Outputs, 4 High Power Outputs, 16 Negative Outputs, 16 Inputs, Wiper Synchronization
010-02220-06202010624v, 12 Outputs, 2 Common Outputs, 16 Inputs
010-02220-07202010724v, 12 Outputs, 4 High Power Outputs, 2 Common Outputs, 16 Inputs
010-02220-08202010824v, 8 Outputs, 4 High Power Outputs, 2 Common Outputs, 16 Inputs
010-02221-082020108W24v, 12 Outputs, 4 High Power Outputs, 2 Common Outputs, 16 Inputs, EnOcean 868MHz (EU)
010-02220-09202010924v , 12 Outputs, 4 High Power Outputs, 2 Common Outputs, 1 Negative Output
010-02220-10202011024v, 12 Outputs, 4 High Power Outputs, 16 Negative Outputs, 16 Inputs, Wiper Synchronization
010-02222-08202040824v, 12 Outputs, 4 High Power Outputs, 2 Common Outputs, 16 Inputs, 2 mA Inputs
Connect 50
010-02225-102110110Connect 50, 20 Outputs, 11 Inputs
010-02225-112110111Connect 50, 20 Outputs, 7 Inputs, CAN, Serial Port
010-02225-122110112Connect 50,  20 Outputs, 7 Inputs, CAN, Serial Port, Wi-Fi
010-02279-012210101Connect 50vb, 12v, 20 Outputs, 8 Inputs, CAN, LIN
010-02279-022110102Connect 50vb, 12v, 20 Outputs, 11 Inputs, Rev Pol Output, Analog Output
010-02225-30N/AConnect 50 v2, 20 Outputs, 11 Inputs,
010-02279-21N/AConnect 50vb v2, Empirbus, 12V, 8/20, CAN, LED Touch
010-02278-21N/AConnect 50 v2, 24v, 20 Outputs, 11 Inputs,
010-02225-31N/AConnect 50 v2, 20 Outputs, 7 Inputs, CAN, Serial Port
010-02279-032210103Connect 50vb, 20 Outputs, 11 Inputs
Connect HPR
010-02280-01N/AConnect HPRb, OHPR18 12,I 4, 12V
010-02280-02N/AConnect HPR, OHPR18 12,I 4, 12V
Master Control Unit (MCU)
010-02575-00N/AProgramming Interface v2
010-02575-10N/AMCU v2, 2xCAN, 2xRS485
010-02223-112051011MCU v1,
010-02223-132051013MCU v1, CAN, Serial Port 232
010-02223-402051040MCU v1, GSM
010-02223-432051043MCU v1,  GSM, CAN, Serial Port 232
Web Display Unit (WDU)
010-02642-00N/AWDU v2
010-02226-002051400WDU v1
Switch Panels
010-02368-002500000SP8, 8-Way Switch Panel, Horizontal, IP67
010-02369-002600000SP8, 8-Way Switch Panel, Vertical, IP67
010-02370-00041323SP12, H-CL, Horizontal
010-02371-002041324SP12, H-CL-D, Horizontal
010-02372-002041363SP12, H-CL, Vertical
010-02373-002041364SP12, H-CL-D, Vertical
Panel Cables
010-12984-572036057SP12, Power Supply, 6mm Ring Terminals
010-12984-562036056Power Supply, 6mm Ring Terminals
010-12984-712036071Deutsch 4 pin Female, M12 Male, 0.75m
010-12984-722036072Molex Crimp Terminal, M12 Female, 0.75m
Temperature Sensors
010-12914-032063101Thermistor Temp Sensor, 100ohm 3200k
010-12914-122063112Temp Sensor w3m Cable, Stainless Steel Tube, 30x7mm
010-12914-132063113Temp sensor w3m cable, Stainless Steel Ring terminal, M5
Transient Voltage Suppression
010-12913-012031201TVS, 12v, 200mm Wire
010-12913-022031202Dual TVS, 12v, 200mm Wire
010-12913-032031203TVS, 24v, 200mm Wire
010-12913-042031204Dual TVS,  24v, 200mm Wire
Molex Connectors
010-12912-012031001MX150L, 16 Circuit Receptacle for 14-16 AWG
010-12912-022031002MX150L, 16 Circuit Receptacle for 18-22 AWG Wire
010-12912-312031031MX150L, Female Terminal for 14-16 AWG Wire, 40 pack
010-12912-322031032MX150L, Female Terminal for 18-22 AWG Wire, 40 pack
010-12912-112031101MX150L, 16 Circuit Receptacle for 14-16 AWG Wire, 60 pcs
010-12912-122031102MX150L, 16 Circuit Receptacle for 18-22 AWG Wire, 60 pcs
010-12912-212031221MX150L, Female terminal for 14-16 AWG Wire (4000 pcs, reel)
010-12912-222031222MX150L, Female Terminal for 18-22 AWG Wire (4000 pcs, reel)
010-12912-302031230MX150L, Circuit Plug Strip
010-12912-332031231MX150L, Circuit Plug Strip (720 pcs)
Accessories
010-12912-412031041Hand Crimp Tool,  14-16/18-22 AWG Wire
010-12912-512031051Manual Extraction Tool
010-12912-702031070Interface cable, 12pin Male M12 to free cable
010-12915-012052001Kvaser Leaf Light, v2 M12
010-02224-002051200ICU
010-12912-712031071USB Cable Master, IP65 USB A to Mini USB B, 2m
010-12912-742031074Antenna, Wi-Fi, 4G, 3m
010-12912-722036080Ethernet Cable, WDU(for WDUv1 only)
010-12912-80N/ABare Wire Cable Harness, x1
010-12912-81N/ABare Wire Cable Harness, x2
