Vesper® XB-6000 Class B AIS Transponder Owner's Guide
The Vesper Marine® XB-6000 is a high-performance AIS transponder with a built-in NMEA 2000 gateway and fast navigation GPS.
Sections:
Installation
The XB-6000 Installation Guide has important information about wiring and antenna placement.
The install guide shows how to connect an optional switch to place the XB-6000 in Silent Mode. This mode allows your XB-6000 to function as a GPS and AIS receiver but will not transmit the vessel's position or other information. When desired, the settings will run in silent mode, for example, during critical times during races. Silent mode is controlled from the vmAIS Configuration and Status Utility (see downloads section).
Installation on Fast Vessels over 45 knots
The GPS smoothing feature optimizes for vessels that do not exceed 45 knots. For faster ships, disable the smoothing feature so that GPS position is not lost when traveling over 48 knots.
To do this:
  1. download the vmAIS Configuration and Status Utility (see downloads section)
  2. install it on a PC or Mac.
  3. Connect to the XB-6000 using the provided USB cable.
  4. Select the GPS tab and untick the Smoothing option.
XB-6000 LED Status Indicator
Refer to the XB-6000 Installation Guide for details about the Status LED. In regular operation, the Status LED will be solid green. It will be solid orange and flashing orange during the first-minute startup period while acquiring a GPS fix.
Use the vmAIS Configuration and Status Utility (see downloads section). Download and install it on a PC or Mac computer using this utility. Connect to the XB-6000 using the provided USB cable.
Select the Status tab to determine why the Status LED is not green. Verify that all status items are ticked. Use the Status tab to view the antenna VSWR and various statistics for each AIS channel.
The GPS tab is used to view the current satellite status and may help determine the best location for the GPS antenna.
Configuring Vessel Details
The XB-6000 will not transmit until the vessel details are configured. The dealer may have already configured this information, following the below steps to confirm all information is correct.
An assigned MMSI number is required for the vessel. Obtain an assigned MMSI, and contact the relevant authority.
MMSI number cannot change it, and it is critical that it's entered correctly. If a change is required on the MMSI, contact an authorized dealer or Garmin Marine.
The vessel details may be configured and viewed using the vmAIS Configuration and Status Utility (see downloads section). Download and install it on a PC or Mac computer to use the utility. Connect the XB-6000 to the computer using the provided USB cable.
Once connected, choose the "Configure Vessel Data" tab to display current details. Enter the MMSI and other information carefully since this information transmits to all vessels within range. Select the most appropriate vessel type and enter the location of the GPS antenna. Information about the GPS location is entered in either meters or feet. Measurements in feet convert to whole meters for transmission. As a result, not all measurements in feet can be represented.
NMEA 2000 Status and Configuration
View the Status and adjust the NMEA 2000 configuration for troubleshooting and advanced installations. To do this, download the vmAIS Configuration and Status Utility (see downloads section) and install it on the PC or Mac computer. Connect the XB-6000 to a computer using the provided USB cable.
Once connected, choose the "NMEA 2000" tab. This tab shows the current NMEA 2000 connection state. It will be green when the XB-6000 is connected to the bus and working correctly. If a detected problem on the bus, the status indicator will be orange. If the XB-6000 is not operating on the NMEA 2000 bus, the status indicator will be red.
Note: It is normal for the red and orange indicators to flicker back and forth every few seconds when there is no NMEA 2000 connection to the XB-6000.
From the NMEA 2000 tab, individual PGNs can be selected to receive and transmit. For example, if the system already has another source for the GPS data set, uncheck the output GPS data. You can also select the output rate for each PGN in milliseconds.
Note: GPS data is updated once per second or five times per second, depending on the configuration settings. Choosing to output the data more frequently repeats the same data until the next update.
Current NMEA 2000 PGN List
PGN's Received:
127250 Vessel Heading
128259 Speed
128267 Water Depth
128275 Distance Log
130306 Wind
130310 Water Temperature
130311 Water Temperature
130312 Water Temperature
130316 Water Temperature
129283 Cross Track Error
192284 Navigation Data
129285 Route/WP Information
PGN's Sent:
129025 Position
129026 COG & SOG
129029 GNSS Positions
129540 GNSS Satellites
129038 AIS Class A Position
129039 AIS Class B Position
129040 AIS Class A Extended Position
129041 AIS Aids to Navigation Report
129794 AIS Class A Static Voyage
129798 AIS SAR Aircraft Position
129801 AIS Addressed Safety
129802 AIS Safety Related Broadcast
129809 AIS Class B "CS" Static, Part A
129810 AIS Class B "CS" Static, Part B
See: NMEA Translations for Watchmate Products
Downloads
XB-6000 Installation GuideHas wiring diagrams, how to interpret the Status LED, information about antenna placement, and connecting NMEA 2000. It also includes troubleshooting information and technical specifications.
Windows: vmAIS Configuration and Status UtilityInstall this utility on a PC running Microsoft Windows (XP or later) to configure or check the MMSI & vessel details, update the NMEA 2000 configuration, monitor GPS and transponder status, assist with troubleshooting and provide for future firmware updates.
Mac OS X: vmAIS Configuration and Status UtilityInstall this utility on Mac OS X (10.7 "Lion" or later) to configure or check the MMSI & vessel details, update the NMEA 2000 configuration, monitor GPS and transponder status, assist with troubleshooting and provide for future firmware updates.
USB drivers for Microsoft Windows
Recent versions of Microsoft Windows include USB drivers. However, if the system does not have the drivers installed, download them from here.
These drivers are supported on Windows XP, Windows Server 2003, Windows Vista, Windows Server 2008, Windows 7, 8, 8.1, 10, and Windows Server 2008 R2.
USB drivers for MAC OS XThe latest USB drivers for MAC OS X.
What Navigation Software Programs are Compatible with a PC or MAC?
Any PC or MAC navigation software that accepts AIS and GPS data over a serial port. Use the USB port on the Vesper Marine® transponder for the serial connection.
Examples of navigation software supporting the XB-6000 are Rose Point Coastal ExploreropenCPN, and macENCExpeditionMaxSea.
There are many other computer navigation software packages that work with AIS data. Check the manual for the software about its support for AIS and how to configure it.
Sumber terkait
