Deleting or Hiding Tracks in the Earthmate App
Within the Earthmate® app, the option to disable or toggle off your tracks under History is not functioning as intended. You may notice that even after disabling or toggling them off, the tracks are still present on the map.
The solution for this is to either hide all tracks by toggling off Show Track Line, or delete specific tracks in History, which should remove them from the map. If tracks or track points are still appearing on the map after deleting them, you may also need to delete them from your inReach device and uninstall and reinstall the Earthmate app. Steps for hiding or deleting tracks are below.
NOTE: Any data not uploaded to the Garmin Explore™ website will be irrevocably lost. Before proceeding, it is a good idea to sync Earthmate and the inReach® device to ensure your data is in your online account. For steps, see Related .
Hiding Tracks
Use the steps below to toggle off the track line and toggle off track points in history.
iOS
Toggling Off "Show Track Line"
  1. Open the Earthmate app.
  2. Touch More.
  3. Select Options.
  4. Select Map.
  5. Toggle off Show Track Line.
Showing Track Points for Specific Days
  1. Follow the instructions above for Toggling Off "Show Track Line."
  2. Then touch More.
  3. Touch History.
  4. Toggle off all days except the ones you want displayed.
  5. Touch Map.
  6. Track points for those specific days will now display.
Android
  2. Touch 3 Dots Icon.
  3. Select Settings.
  4. Select Map.
  5. Deselect Show Track Line.
  2. Touch Three Lines Menu Icon.
  3. Touch History.
  5. Touch Three Lines Menu Icon.
  6. Touch Map.
  7. Track points for those specific days will now display.
Deleting Track Points for Specific Days
Use these steps to remove track points for specific dates. To remove the actual track lines from the map, see - Deleting All Tracks .
iOS
Removing Specific Track Logs in the Earthmate App
  1. Power on the inReach device.
  2. Open the Earthmate app.
  3. Confirm the inReach is Connected:
    1. Touch More.
    2. Touch My inReach (it may take a moment for the device to appear).
  4. Touch More again.
  5. Select History.
  6. Select the desired date.
  7. Touch Share Icon.
  8. Select Delete Day.
  9. Select Delete.
Deleting Tracks From the inReach Device
If the tracks still appear, they are likely still on the inReach device and are therefore syncing back to the Earthmate app from the device. To resolve this, the tracks can either be deleted from the inReach.
inReach Mini
  1. From the home page that displays the time and battery status, scroll down and select Tracking.
  2. Press OK to see the current tracking intervals and start tracking.
  3. Press OK again to reach the tracking menu.
  4. Select Clear Log.
  5. Select Yes.
  6. Select Stop Tracking.
inReach SE®/inReach Explorer®
  1. Select History.
  2. Tracks are sorted by the date they were recorded, select one from the list.
  3. Select Delete.
  4. Select Delete again.
    • NOTE: This will also delete any messages and waypoints done that same day.
Perform steps 2-4 for any additional dates of tracking data.
inReach SE+/inReach Explorer+
  1. Select History.
  3. Press Three Lines Menu Key.
  4. Select Delete All History.
  5. Select Delete.
Uninstalling and Reinstalling the Earthmate App
If the deleted track points are still appearing after deleting them from Earthmate and the inReach device, you may need to uninstall and reinstall the Earthmate app.
null
Pairing Your inReach Again
After reinstalling the Earthmate app you will need to pair your inReach device again. For instructions, see - Pairing Instructions for Earthmate Compatible inReach Devices.
Android
    1. Touch Three Lines Menu Icon.
  4. Touch Three Lines Menu Icon again.
  5. Select History.
  7. Touch 3 Dots Icon.
inReach Mini
  5. Select Yes.
  1. Select History.
  3. Select Delete.
  1. Select History.
  5. Select Delete.
null
Deleting All Tracks
Use these steps to delete all tracks from the Earthmate app and your connected inReach device.
iOS
Deleting All Track Points
    1. Touch More.
  5. Select History.
  6. Touch Share Icon.
  7. Select Delete All.
  8. Select Delete.
Clearing the Track Logs in Earthmate
  2. Touch Tracking.
  3. Touch Share icon.
  4. Select Clear.
    • NOTE: After selecting clear, you will get a message to verify clearing the log.
      Earthmate iPhone clear log message
  5. Select Clear again.
Resetting the inReach Device
IMPORTANT: Resetting the inReach device also resets its settings, so you will need to re-pair with the Earthmate app on your smartphone/tablet. It is also a good idea to make note of your settings to replicate them after resetting.
  1. Select Setup or Settings.
  2. Select Recovery Options.
  3. Select Restore Defaults or Factory Settings.
  4. Plug in and re-sync your inReach on the computer. For steps, see Related .
If the deleted track points or logs are still appearing after deleting them from Earthmate and the inReach device, you may need to uninstall and reinstall the Earthmate app.
null
Android
  5. Select History.
  6. Touch 3 Dots Icon.
  8. Select OK.
  2. Touch android menu icon.
  3. Select Tracking.
  4. Touch 3 Dot menu icon.
  5. Select Clear Log.
      Earthmate android log message
  6. Select Clear again.
null
Sumber terkait
