Press MENU twice to access the main menu.
Select Setup.
Select Map.
Select Advanced Map Setup.
Select Adjust Zoom Ranges.
Select Zoom Levels.
Geocaches Not Appearing on a GPSMAP Handheld
The following GPSMAP® handhelds will only display geocaches located within a 100-mile radius of the device or a selected position:
GPSMAP 64 | GPSMAP 64s | GPSMAP 64sc | GPSMAP 64st | GPSMAP 64sx | GPSMAP 64csx | GPSMAP 64x
GPSMAP 65 | GPSMAP 65s
GPSMAP 66i | GPSMAP 66s | GPSMAP 66sr | GPSMAP 66st
GPSMAP 67 | GPSMAP 67i
GPSMAP 86i | GPSMAP 86s | GPSMAP 86sc | GPSMAP 86sci
In order to search or view geocaches that are more than 100 miles from where you are located, utilize the Search Near option and select a map point within a 100-mile radius of the geocache you wish to view.
Using Search Near
Select Geocaches/Geocaching.
Press MENU.
Select Search Near.
Select an option for changing the area the device searches from.
Utilizing the Search Near feature on these devices will allow you to search for geocaches outside the 100-mile radius from your current location with the GPS.
My Geocache Still Is Not Appearing on the Map
If your geocache still is not visible on the map itself, it is best to ensure the zoom level set for your geocaches is not the issue. The map items do not appear when the map zoom level is off or higher than the selected level. Select your device below for the steps to check the geocache zoom level.
Checking the Geocache Zoom Level
NOTE: This setting is not available on the GPSMAP 62 series.
Clearing Geocache Filters
Remove any geocache filter that could be interfering with viewing the geocache.
My Geocache Still is Not Showing
If your geocache still is not visible, you will want to delete the geocache from your device and add it back to your device.
For information on deleting geocaches, see - Using BaseCamp™ to Delete Geocaches From an Outdoor Handheld.
