Pairing the Alpha 200/200i With the Garmin Explore App
Using an Alpha® 200 or Alpha® 200i and the Garmin Explore™ app, view your live hunting activity and dog tracking information right on a smartphone. The Garmin Explore app has many other helpful features, such as: downloading topography and satellite imagery maps to the smartphone, marking waypoints, reviewing previous activities, and creating routes. The following guide will show how to get started with pairing the Alpha 200 or Alpha 200i with the Garmin Explore app, and also gives links to helpful videos and FAQ tutorials.
NOTE: The Alpha 200 and Alpha 200i do not pair with the Garmin Connect™ app.
Getting Started: Updating Software and Pairing to the Garmin Explore App
Before Beginning
Update the software on the Alpha 200/200i to the latest version
Install the latest Garmin Explore app on a smartphone with either Google Play for Android or the App Store for iOS
After downloading the app, log in with the Garmin account credentials or create an account by selecting Create One and follow the prompts
Ensure Bluetooth is enabled in the smartphone settings
Pairing Procedure
Instructions for pairing will vary slightly depending on whether or not you have used the Garmin Explore app previously.
First Time Users
Install and open the Garmin Explore app.
Allow any app permissions when prompted.
Select Create Account.
NOTE: If you already have a Garmin account or have previously used other Garmin apps, you can select Sign In (or Continue as ['username'], if prompted).
Tap Next after reading and agreeing to the EULA.
Tap Enable Cloud Storage (or Not Now).
Continue selecting Done to proceed through the information about new app features.
Select Add Device when prompted.
The app will then begin searching for devices.
On the Alpha model, enable pairing mode:
You can enable pairing mode on the Alpha by selecting > Setup > Bluetooth > Continue.
If your Alpha is currently connected with the Alpha app on your phone, skip to the next step.
In the Garmin Explore app, select Connect It and follow the prompts to complete the setup.
The Alpha handheld will now be paired with the Garmin Explore app.
Existing Garmin Explore App Users
Open the Garmin Explore app.
If prompted, read and agree to EULA, and sign in.
Select Devices.
Select either + Pair a New Device or .
Overview of Features on the Garmin Explore App
Creating waypoints and routes/courses
Reviewing recorded tracks
Downloading detailed topographic and satellite imagery maps directly to the smartphone
Organizing data into Collections to show or hide previous activities on the map
Syncing data to the Garmin Explore website for cloud based storage
New Features Enabled When Paired a Dog Tracking Device
Shows Dog Status icon – treeing, pointing, sitting
Shows Dog Name
Dog Track Color matches the colors on handheld – red, blue, black
You can adjust how long the dog tracks show on the map
Dog movement Speed Indicator
Any part of the track that shows a segment of the dog moving faster than a certain speed will show up as a thicker line on the map
Useful to know if the dog is chasing something during a hunt
Choose either faster than 5 mph, 10 mph, 15 mph, or Off
Select Map.
Select .
Select .
Select Map Settings.
Select Line Display Settings (Android) / Dog Mode Settings (iOS).
Select Speed Indicator.
Dog Hunts saved as an Activity
Play Back feature: Plays back the dog's hunting activity
Select Saved.
Select the name of the hunt you want to review.
Select the dog you want to review from the List.
Touch the play button.
For guidance on how to use many other features of the Garmin Explore app, see the following videos and the Related Content links below.
Helpful Videos
The videos below are designed to give you information on:
