User Data Limitations of the GPSMAP 67 Series
When sending or creating files for a GPSMAP® 67 or 67i outdoor handheld, keep in mind the following limitations:
2,000 GPX files
10,000 waypoints
No limit on geocaches (outside of max number of GPX files supported and memory available)
250 routes, 250 points per route; 50 points turn-by-turn routing
250 courses, 200 course points per course
250 saved tracks
300 saved fit activities
2,000 archive tracks1
20,000 points per track
500 custom map tiles
100 Satellite Imagery JNX files can be downloaded using Map Manager on the handheld
A combined total of 250 JNX files can be added when using BaseCamp software to add Birdseye imagery
15,000 Mapping segments2
Each GPX file can contain a mixture of waypoints, geocaches, routes and tracks. If the GPX file containing a waypoint or geocache is deleted, the waypoint will no longer be available on the device.
When utilizing routes, only 50 points can be used for turn-by-turn navigation on roads or trails.
1 Archive tracks do not count against the GPX file limit; 1 archive track per GPX file.
2 See Related for more information on map segments.
