お使いの機種名を選択して、この情報が該当するかどうか確認してください。
Using a Minn Kota Trolling Motor Transducer With a Garmin Marine Device
Minn Kota offers some trolling motors with a transducer built-in. A few select Garmin chartplotters can connect to the Universal Sonar 2 transducers and the Dual Spectrum CHIRP transducers that are built in to some of the Minn Kota trolling motor using a Minn Kota adapter cable. The below lists are grouped by sonar pin configuration with the corresponding adapter part number. Once connected, refer to the chartplotter owner's manual and refer to "Selecting the Transducer Type" to select the Minn Kota option.
4-pin Garmin Chartplotters and Fishfinders
If the Garmin chartplotter or fishfinder requires a 4-pin transducer, use the MKR-US2-12 part for Universal 2 transducers or the MKR-DSC-12 part for Dual Spectrum CHIRP transducers.
echo™ fishfinders
echoMAP™ 4x chartplotters | echoMAP™ 5x chartplotters | echoMAP™ 7x chartplotters | echoMAP™ 9x chartplotters
echoMAP™ CHIRP 4x chartplotters | echoMAP™ CHIRP 5x chartplotters
ECHOMAP™ Plus 6x chartplotters
ECHOMAP™ UHD 6x chartplotters
ECHOMAP™ UHD2 5x chartplotters | ECHOMAP™ UHD2 7x keyed chartplotters
STRIKER™ fishfinders | STRIKER™ Plus fishfinders | STRIKER™ Vivid fishfinders
6-Pin Garmin Chartplotters
If the Garmin chartplotter requires a 6-pin transducer, use the MKR-US2-1 part.
8-pin Garmin Chartplotters
If the Garmin chartplotter requires an 8-pin transducer, use the MKR-US2-14 part for Universal 2 transducers or the MKR-DSC-14 part for Dual Spectrum CHIRP transducers.
echoMAP™ 50 chartplotters | echoMAP™ 70 chartplotters
echoMAP™ CHIRP 7x cv chartplotters | echoMAP™ CHIRP 9x cv chartplotters
GPSMAP® 5x7 chartplotters | GPSMAP® 7x1 chartplotters
GPSMAP® 7x2 chartplotters | GPSMAP® 9x2 chartplotters
GPSMAP® 8x0 chartplotters | GPSMAP® 10x0 chartplotters
GPSMAP® 10x2 chartplotters | GPSMAP® 12x2 chartplotters
GPSMAP® 74xx chartplotters | GPSMAP® 76xx chartplotters
- GPSMAP® 84xx chartplotters | GPSMAP® 86xx chartplotters
12-pin Garmin Chartplotters
If the Garmin chartplotter requires a 12-pin transducer, use Garmin's adapter cable part number 010-12122-10 and MKR-US2-14 part.
echoMAP™ CHIRP 7x chartplotters | echoMAP™ CHIRP 9x chartplotters
ECHOMAP™ Plus 7x chartplotters | ECHOMAP™ Plus 9x chartplotters
ECHOMAP™ UHD 7x chartplotters | ECHOMAP™ UHD 9x chartplotters
ECHOMAP™ UHD2 6x chartplotters | ECHOMAP™ UHD2 7x touch chartplotters | ECHOMAP™ UHD2 9x chartplotters
ECHOMAP™ Ultra chartplotters
GPSMAP® 7x3 chartplotters | GPSMAP® 9x3 chartplotters | GPSMAP® 12x3 chartplotters | GPSMAP® 16x3 chartplotters
Devices not listed above can use the 200kHz frequency but will not utilize the 83kHz frequency. The appropriate adapter is still required.
