お使いの機種名を選択して、この情報が該当するかどうか確認してください。
Clearing or saving recently found places on an automotive device
The Recently Found list temporarily stores your last 50 entries. Once you locate 50 places, the oldest entry disappears and the newest location is added to the top. You may clear the list of recent items at any time.
If you need to save a recently found location permanently, you can save it to your Favorites. You cannot, however, delete individual items from the recently found list.
To remove all entries from the Recently Found list:
  1. Touch Where to?
  2. Touch Recently Found
  3. Touch Clear at the bottom of the page
  4. Touch Yes to confirm that you want to clear the list
The list of recently found locations will now be empty. As you find more locations on your device, the Recently Found list will repopulate. Repeat the steps above to clear the list when desired.
To save a recently found location to your favorites:
  1. Access the list of recently found locations per the steps outlined above for your device
  2. Touch the location you want to save
  3. Touch Save
  4. If your model asks you to enter a name for the location, type the name then touch Done
The location may now be accessed in your device's Favorites list. Repeat these steps as desired for any additional recently found locations that you would like to save to your Favorites.
