お使いの機種名を選択して、この情報が該当するかどうか確認してください。
現在閲覧中の記事は、現在選択された言語をサポートしておりません。以下ドロップダウンメニューにて他の言語に変更できます。
(2024) ASDN Service Bulletin 23031 Rev C: GTX 45R/GTX 345 Series ADS-B Software Version 3.41
PRODUCTS AFFECTED:
The following GTX 45R/GTX 345 series units are affected:
Model | Appliance P/N |
GTX 345 | 011-03302-0( ) |
GTX 345 GPS | 011-03302-4( ) |
GTX 345R | 011-03303-0( ) |
GTX 345R GPS | 011-03303-4( ) |
GTX 345 NV | 011-03302-2( ) |
GTX 345 NV, GPS | 011-03302-6( ) |
GTX 345D | 011-04333-00 |
GTX 345DR | 011-04334-00 |
GTX 45R | 011-04287-0( ) |
GTX 45R GPS | 011-04287-4( ) |
CERTIFICATION AUTHORIZATION:
TSO Authorization
COMPLIANCE:
Recommended: Compliance with Service Bulletin 23031 is recommended at the next scheduled maintenance interval.
PURPOSE:
GTX 45R/GTX 345 Series ADS-B Software Version 3.41 contains the following changes:
- Corrected an issue described in Garmin Service Advisory 23009 that prevents the appearance of some traffic targets while the Basic Surface Situation Awareness (SURF) application is active.
- Corrected an issue where some 1090ES ADS-B and ADS-R surface targets may erroneously appear as directional.
NOTE
This also provides improved “look-ahead” hover-taxi alerting in rotorcraft.
- Removed transmittal of Non-Performing Emitter (NPE) traffic data from HSDB to other connected Garmin devices.
NOTE
This addresses a traffic display compatibility issue in some G3X™ installations as described in Garmin Service Advisory 23023. NPE data is still transmitted using Connext® over wired serial interfaces and Bluetooth.
WARRANTY INFORMATION:
This modification is warranty reimbursable with a deadline of September 29, 2023.
