お使いの機種名を選択して、この情報が該当するかどうか確認してください。
What is Used to Calculate Calories on My Multi-Sport Watch?
Depending on what accessories are used with the watch, calories burned during a recorded activity will be calculated in the following order:
- Firstbeat - calculated using heart rate user profile data
- Power Meter - calculated using instantaneous power
- Fitness Equipment - calculated using ANT+ enabled fitness equipment
- Speed, Distance, and User Profile - calculated using speed, distance, and user profile data
The device will automatically choose the appropriate method. There will be slight variations depending on the method used.
NOTE: Some older Garmin products feature New Leaf as a means to calculate calories burned. This feature would hold precedence over the below methods however Garmin no longer supports New Leaf profiles.
