お使いの機種名を選択して、この情報が該当するかどうか確認してください。
現在閲覧中の記事は、現在選択された言語をサポートしておりません。以下ドロップダウンメニューにて他の言語に変更できます。
Troubleshooting Interference on the Alpha 200 Series Handheld
Conflicting IDs
Collars are automatically allocated ID numbers on open frequencies and channels when being added to the handheld. There are three main reasons you can get interference:
  1. Frequency is overloaded, too many dogs on one frequency.
    • Space out the dogs on different frequencies and channels.
  2. Channel number is repeated or are listed too close together.
    • Try to space out the channels at least 5 apart on each frequency.
  3. Hunters in same area using the same frequency and channel.
    • When hunting with others check to make sure your dogs and handhelds do not have conflicting frequencies.
Groups and Interference
Alpha® 200 series dog tracking handhelds have ability to add groups for hunters that hunt with multiple hunting partners.
Activating and Deactivating Tracked Devices in Alpha 200i Groups
Pairing Up to 250 Dogs for the Alpha 200: Adding, Grouping, and Deactivating
Interference Notification Icon on the Alpha 200i
関連コンテンツ
