お使いの機種名を選択して、この情報が該当するかどうか確認してください。
現在閲覧中の記事は、現在選択された言語をサポートしておりません。以下ドロップダウンメニューにて他の言語に変更できます。
Replacing the Temperature Probe in a Transducer
The AirMar B744 series transducer has a temperature probe built into the transducer. The transducer does not need to be replaced if the temperature probe goes out on the unit. Airmar has created a junction box and insert kit. The kit allows the replacement of the temperature probe and the speed sensor if either one should quit functioning. To purchase the equipment, contact Gemeco Marine Accessories at 803-693-0777.
If the temperature probe on an 8-pin Garmin transducer goes out, an Airmar T80 Water Temperature Probe can be installed in line with the transducer to restore temperature. This accessory pigtails into the existing transducer cable. The temperature sensor piece mounts to the vessel's exterior.
