お使いの機種名を選択して、この情報が該当するかどうか確認してください。
Create a Manual Activity in Garmin Connect Mobile
Garmin Connect Mobile will allow you to manually enter an activity using basic information. This feature can be used when you are unable to record an activity because of an issue with your fitness device or when you do not have access to a fitness device.
To add a manual activity in Garmin Connect Mobile:
  1. Open Garmin Connect Mobile
  2. Access the Menu
  • Android: Select
  • iOS: Select More
  1. Select Create Manual Activity
  2. Enter all applicable fields
  3. Select Save
Your manual activity is now entered.
