お使いの機種名を選択して、この情報が該当するかどうか確認してください。
現在閲覧中の記事は、現在選択された言語をサポートしておりません。以下ドロップダウンメニューにて他の言語に変更できます。
Register or Transfer the Vault Service to a New or Replacement Garmin Dash Cam
To avoid signing up for another subscription and needing to cancel the old subscription, you can transfer an existing subscription to a new or replacement device.
Garmin Dash Cam™ subscriptions can be transferred in the Account Manager.
See the Garmin Vault LTE | Vault Storage plan page for an overview and list of compatible devices.
To Register your New/Replacement Device:
- Sign in to your Subscription Portal
- Select MANAGE for your original device
- Select Transfer your plan to a different compatible device
- Select REGISTER
- Enter the serial number of the new or replacement device
- Select SUBMIT
The replacement device will now be registered.
To Transfer the Subscription to your New/Replacement Device:
- Log in to the Subscription Portal
- Select MANAGE on the device you want to change
- Select Transfer your plan to a different compatible device on the subscription you want to change
- Select the replacement device
- If you have not already added the new/replacement device to your account, you will need to register it in the Subscription Portal by following the instructions above.
- Select Confirm
The subscription has now been transferred to your replacement device.
NOTE: To fully complete the service transfer, the replacement device will need to be paired with the Garmin Drive™ app or dēzl™ app.
