เลือกผลิตภัณฑ์ของคุณเพื่อให้มั่นใจว่าข้อมูลนี้สามารถนำไปใช้ได้
Purchasing a New Map for an Outdoor Device
Garmin offers a wide variety of maps for our products. If you are planning to travel and require a new map, follow these instructions to help you purchase and install the new map to your device. Any maps that came preloaded on your device will still be able to be used after installing the new maps. The purchase process is quick and easy, however the installation process may take several hours to complete depending on the map you select and the speed of your internet connection. Once the installation is started, the device can be left unattended until it is complete.
Note: If the purchase has already been completed and assistance is needed to install the map, see null.
What is needed:
- A compatible Garmin device
- A USB cable
- An SD card may be required if the map will not fit on the internal storage of the device
- The storage space requirements can be found on the REQUIREMENTS tab on the purchase page for the map.
- A Windows or Mac computer with the Garmin Express application installed.
- For assistance with installing Garmin Express, see Install Garmin Express
- A high-speed internet connection
- DSL, Cable, or other high speed Internet connections are recommended. Mobile broadband (such as MiFi, AirCard, or cell phone tethering), satellite, fixed wireless, and dial-up Internet connections are not supported.
- A credit card for purchasing the map
To purchase the map:
- Select the desired map from our Outdoor Maps page.
- Click the COMPATIBLE DEVICES tab to make sure that the map is compatible with the device. If the device is listed, it can be installed to the device.
- Select Download in the Version drop down box and click ADD TO CART.
- Verify the order is correct and then click CHECK OUT.
- Sign in or create a Garmin account if prompted.
- Select the shipping address or enter a new one and click CONTINUE.
- Enter the billing address and click CONTINUE.
- Verify the order information is correct and click CONTINUE TO PAYMENT.
- Fill in the credit card information fields and click PLACE SECURE ORDER.
A Confirmation screen will be displayed when the order is complete and the map is ready to install to the device.
To install the map with Garmin Express:
- Connect the Garmin device to the computer with the appropriate USB cable.
- From the order confirmation page, click LAUNCH GARMIN EXPRESS.
Note: If Google Chrome is used to make the purchase, click Open URL:garminexpress if prompted.
- Select the device and click Continue
- If the device was not already added to Express a window will display stating that the device was added to Express. If this occurs, click OK and then choose whether or not to allow the collection of data.
- Click the download icon
- Click Accept on the license agreement.
- Read the important notes and click Continue.
- Click Continue next to the Memory Card or Device.
- If the size of the map exceeds the internal storage of the device, an SD card will be required.
Once the download starts, Garmin Express will display the current progress. An Installation complete! message will be displayed when the download is finished and the device can be safely disconnected from the computer. If any issues are encountered with this process, visit the Garmin Express Support page for troubleshooting assistance and options for contacting Product Support.
