เลือกผลิตภัณฑ์ของคุณเพื่อให้มั่นใจว่าข้อมูลนี้สามารถนำไปใช้ได้
คุณกำลังดูบทความที่ไม่มีในภาษาที่คุณเลือกในปัจจุบัน คุณสามารถเลือกรายการอื่นด้านล่าง
Format a USB Flash Drive for use with a Kenwood Device
Many Kenwood devices use a USB Flash Drive for updating software and preloaded maps. The USB flash drive may require formatting before it can be used. The maximum memory size supported by Kenwood is 32GB.
To Format the USB Drive:
Windows
1. Insert the USB drive into the computer
2. Press the Windows key + E
3. Click This PC (Windows 10 only)
4. Locate the drive representing the USB drive
  • To determine which drive is the USB drive:
    1. Remove the USB drive from the computer
    2. Observe which drive disappears from the list
    3. Insert the USB drive again
5. Right-Click on the USB drive
6. Click Format
7. Verify the File System is FAT or FAT32
8. Change Allocation unit size to Default allocation size
9. Ensure Quick Format is checked
10. Click Start
These steps will format the USB drive to be readable by Garmin Express and the Kenwood navigation system.
Try another USB flash drive if an error is received or formatting the USB drive fails to resolve the issue.
Mac
2. Open Spotlight (CMD + Space) on the keyboard
3. Type Disk Utility into the Spotlight search box
4. Press Return
5. Click the parent icon for the USB drive in the sidebar on the left
  • This is not necessary on Mac OS X 10.12 and newer
6. Click Erase at the top of Disk Utility
7. Select MS-DOS (FAT) in the Format drop-down menu
8. Type a name/title for the USB drive
  • Do not leave the name as "UNTITLED" or "NO NAME"
9. Click Erase
