Chọn sản phẩm để xác nhận thông tin này đang áp dụng cho thiết bị của bạn
Bài viết bạn đang truy cập hiện không có phiên bản Tiếng Việt, vui lòng chọn một trong các ngôn ngữ khác dưới đây.
Options Are Missing From the Main Menu on My Outdoor Handheld
The main menu or app drawer can be customized on outdoor handhelds to add or remove certain items. If there are items missing from the main menu or app drawer, they can be added by following the steps below. These are general steps that will apply to most devices. For more detailed instructions, refer to "Customizing the Main Menu" or "Customizing the App Drawer" in your owner's manual.
Non-Touchscreen Devices
NOTE: For some devices, if you add a page to the main page sequence, it no longer appears on the main menu. Refer to "Page Sequence Setup" or "Changing the Page Sequence" in your owner's manual for detailed instructions. For the Colorado® series outdoor handhelds, refer to "shortcuts" in your manual.
  1. Go to the main menu.
  2. Press Menu or select Edit.
  3. Select Change Item Order.
    • For eTrex® SE, eTrex® Solar, and Rino® 700 outdoor handhelds, skip this step.
  4. Select + Add or Add Page.
  5. Select a category if prompted, then select the item you wish to add.
Touchscreen Devices
eTrex® Touch 25 | eTrex® Touch 35 | eTrex® Touch 35t
  1. Tap the power key to open the app drawer.
  2. Tap 3 lines icon.
  3. Select Setup Drawer.
  4. Select Add.
  5. Select a category, then select the item you wish to add.
Oregon® 200 | Oregon® 300 | Oregon® 400t | Oregon® 400c | Oregon® 400i | Oregon® 450 | Oregon® 450t | Oregon® 550 | Oregon® 550t
  1. From the main menu, select Setup.
  2. Select Main Menu.
  3. Items that are currently hidden from the main menu will be grayed out. Select any grayed out item, then tap + to add it back to the main menu.
Oregon® 600 | Oregon® 600t | Oregon® 650 | Oregon® 650t
  1. Select Setup.
  3. Tap 3 lines icon.
  4. Select Setup Drawer.
  5. Select Add.
  6. Select a category, then select the item you wish to add.
Oregon® 700 | Oregon® 750 | Oregon® 750t
NOTE: The Oregon 700, 750, and 750t use Activity Mode by default, but the mode for these devices can be changed going to the app drawer and selecting Setup > System > Mode.
Activity Mode
  4. Select Add.
Classic Mode
  1. From the home screen, open the app drawer by swiping:
    • Bottom to top (Portrait).
      -or-
    • Left to right (Landscape).
  2. Select Setup.
  3. Select Main Menu.
  4. Tap 3 lines icon.
  5. Select Setup Drawer.
  6. Select Add.
  7. Select a category, then select the item you wish to add.
Montana® 600 | Montana® 600t Camo | Montana® 610 | Montana® 610t Camo | Montana® 650 | Montana ® 650t | Montana® 680 | Montana® 680t
  1. From the home screen, tap Arrow Bracket to open the app drawer.
  2. Select Setup.
  6. Select Add.
Montana® 700 | Montana® 700i | Montana® 710 | Montana® 710i | Montana® 750i | Montana® 760i
  1. Select Hometo access the main menu.
  2. Select Add Page.
  3. Select a category if prompted, then select the item you wish to add.
Rino® 610 | Rino® 650 | Rino® 650t | Rino® 655t
  3. Items that are currently hidden from the main menu will be grayed out. Select any grayed out item, then tap on another item in the menu to add it back to the main menu.
Rino® 750 | Rino® 750t | Rino® 755t
NOTE: The Rino 750, 750t, and 755t use Classic Mode by default, but the mode for these devices can be changed going to the app drawer and selecting Setup > System > Mode.
Classic Mode
      -or-
  2. Select Setup.
  6. Select Add.
Activity Mode
  4. Select Add.
