请选择您的设备来获取相应的信息
此文章暂不支持您所选语言,请重新选择其他语言。
Sending a Message on the inReach Mini 2
When using an inReach® Mini 2 device, it is possible to compose messages through the the Garmin Messenger™ app, the Garmin Explore™ app, or through the device itself. The instructions below will walk through the process of composing a message and how to access additional keyboard options for numbers, symbols, or upper-case alphabet on an inReach Mini 2 device.
Watch Our Video
Typing a Message on the inReach Mini 2
  1. Start a new message, or reply to an existing conversation.
    • New Message:
      1. From the home page, press OK to open the main menu.
      2. Select Send Message.
      3. Choose recipients from your contacts list, or select Type Contact to enter each recipient's contact information.
      4. Select Next.
    • Existing Conversation:
      1. From the home page, press Up Button or Down Button to scroll through the widget glances.
      2. Select Messages.
      3. Select a conversation.
      4. Select Reply.
  2. Select Type Message.
  3. Press Up Button or Down Button to scroll through the alphabet.
  4. Press OK to select a letter.
    • After entering a letter the autocomplete prompt will appear:
      Autocomplete Prompt
  5. Continue typing letters to complete the message.
    • To use autocomplete:
      1. Hold OK.
      2. Select a word from the list of suggestions.
      3. Press Back Button to go back to selecting individual letters.
        Keyboard Example
  6. After finishing the message select Checkmark.
  7. Select Send.
The message will now be sent.
Selecting Numbers, Symbols, or Discarding a Message
At the top of the alphabet list are several options:
Arrow Pointing Left Cursor left
Arrow Pointing Right Cursor Right
Delete Key With X Backspace
Checkmark Finished
Trash Can Discard
Space Bar Symbol Space
Press Back Button to cycle through additional options for numbers, symbols, or upper-case alphabet, or press and hold Back Button to discard a message. You can also select Globe Symbol to change the keyboard language.
InReach Mini 2 Symbols
Related
