Cycling dynamics are metrics and visual displays based upon data recorded by compatible dual sensing power meter pedals. This data is then transmitted and displayed on compatible Garmin Fitness and Outdoor devices. Cycling dynamic data can also be analyzed in your Garmin Connect™ account by uploading and viewing the details of the activity.
In order to record cycling dynamics data during your ride, you must meet the following requirements:
You own a dual-sensing Rally, Vector 3, or a compatible third party power meter set.
Rally™ RK200, Rally™ RS200, or Rally™ XC200.
Vector™ 3 (Vector 3S is not a dual-sensing power meter pedal).
Check with the manufacturer to see if a third party power meter is compatible with Cycling Dynamics.
Your pedals are paired to your head unit or watch via the ANT+ channel.
Cycling dynamics data will not transmit via BLE (Bluetooth Low Energy).
To check, view Sensors > Power Meter > Connection Type.
If you have the option, simply select ANT+ and the channel will switch from BLE to ANT+.
Pairing Pedals to the ANT+ Channel
If you need to unpair your pedals in order to pair them via ANT+, select one of the options below to reveal instructions. Otherwise, refer to your owner's manual.
Edge: Button Controlled
Access the menu of the device.
Select Settings (Edge 540 Series, skip to Step 3.)
Select Sensors.
Locate and select your paired power meterpedals.
Select Remove > Yes.
Select Add Sensor > Search All from Sensors.
Select Power.
Pair the power meter again.
Edge: Touchscreen
Select .
Select Sensors.
Select the paired power meter.
Select Remove.
Select Yes.
Select Add Sensor.
Select Search All from Sensors.
Select Power.
Garmin Watches
Hold UP/MENU (middle left button) to access the main menu.
Scroll to or select Settings.
(Optional) on some watches, select Connectivity.
Select Sensors & Accessories.
Select Remove.
Select Yes.
Select Add New.
Select Search All from Sensors & Accessories to pair the power meter again.
Garmin Devices Compatible With Cycling Dynamics
Choose an option below to reveal a list of devices.
Edge Cycling Computers
Edge® 520
Edge® 520 Plus
Edge® 530
Edge® 540 | Edge® 540 Solar
Edge® 820
Edge® 830
Edge® 840 | Edge® 840 Solar
Edge® 1000
Edge® 1030 | Edge® 1030 Plus
Edge® 1040 | Edge® 1040 Solar
Edge® 1050
Edge® Explore 21
1The Edge Explore 2 will detect Cycling Dynamics and display after the activity is saved and uploaded to Garmin Connect, but will not be able to display them live on the unit during the activity.
Watches
D2™ Mach 1 | D2™ Mach 1 Pro
Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition
