请选择您的设备来获取相应的信息
inReach Mini Firmware Update Release Notes
The inReach® Mini device firmware updates provide inReach satellite communicators with new features and capabilities. Unlike previous inReach versions, the inReach Mini's firmware is updated thru the Garmin Express™ application. Firmware updates must be done via a computer and cannot be done using the Earthmate® app. For more information on updating the inReach Mini firmware via Garmin Express software, see - Updating the Firmware and Syncing Account Information to an inReach Mini.
v3.90 August 16th, 2024
Change Log
- Removed social contacts: Facebook and Twitter
v3.80 April 8th, 2022
New
- Added support for forwarding text messages
- Updated translations
Fixes
- Fixed issue with entering or editing UTM coordinates that are near the equator
- Fixed issue with data use counts not resetting at the start of a new year
v3.70 May 10th, 2021
Fixes
- Fixed potential issue with missing tracking send intervals after updating to software version 3.60
v3.60 April 27th, 2021
NOTE: If your inReach plan includes 2+ minute tracking intervals and 2 and 5 minute send interval options are missing after updating to 3.60, connect the inReach Mini to a computer and sync with inReach Sync (see Updating the Firmware and Syncing Account Information to an inReach Mini).
New
- Added support for disabling the page timeout on the Location and Compass pages
- Added support for updating the address of a message received from an unknown address
Fixes
- Fixed issue with the display of some marine weather data
- Fixed issue with displaying incorrect UTM zone letters in the southern hemisphere
- Fixed issue with occasionally failing to complete a Mail Check
v2.80 February 27th, 2020
New
- Added ability for connected inReach Remote devices to use SOS Quick Text messages
- Added ability to remove Verified devices when ANT+ is not enabled
Fixes
- Improved performance of receiving multiple inReach messages
- Applied Bluetooth security patch
- Fixed issue with creating waypoints from inReach messages
- Fixed issue causing connected inReach Remote devices to show duplicate Preset Messages
- Fixed issue with displaying incorrect tracking intervals after checking for a Plan Update
- Fixed issue with displaying erroneous cold temperature warnings
- Fixed issue with time being incorrect after powering on the device
- Fixed issue with displaying incorrect battery percentage when fully charged on USB power
v2.70 November 27th, 2019
New
- Added a new setting for controlling auto power off behavior when connected to external power
v2.60 March 20th, 2019
New
- TracBack®.
- Navigate back along tracks to your starting point
- TracBack®.
Fixes
- Addresses possible lockup caused by ANT+ upon Factory Reset
- Resolved issue that could cause missing weather icon for last time slot in forecast
- Shifted daily high and low times for improved accuracy
- Updated Bluetooth security patch
- Fixed bug that prevented message read status from syncing to app
v2.50 November 7th, 2018
Fixes
- Addresses issue where time could be wrong due to Daylight Savings
v2.40 October 26th, 2018
New
- Added support for Hungarian, Greek, Bulgarian, Slovak, and Turkish
Fixes
- Fixed issue where text would be temporarily missing after re-sending a message
- After changing languages and then pressing Back, the menus will be in the correct language
- Fixed potentially missing "too hot" icon when device would not charge at high temperatures
- Reduced chance of almost identical points being created when Tracking and Logging at the same time
- Resolved minor issue when device was using extra power at idle
- Reliability improvements for inReach Remote ANT+ users
- Solved issue where the Weather page may open to the wrong time slot
- Add more space to certain Weather pages when the weather provider name did not fit
- Fixed issue which was causing the chance of precipitation to be a negative number
- Fixed issues with UTM / UPS coordinate editing
v2.30 September 6th, 2018
New
- Added XT icon for Extended Tracking
- Added ANT+ logo in the status bar when using inReach Remote
- Improved ANT+ wireless performance for range and reliability
- Modified Auto On / Auto Off behavior
- Added meters per second as an available unit for reporting wind speed
- Disabled GPS logging by default. This will apply to new devices and factory reset devices (Setup → Tracking → Log Interval)
- Updated text strings for various languages
Fixes
- Resolved numerous inReach Remote issues when using ANT+ connected devices
- Fixed issue on the Weather page and home screen where condition icon and precipitation chance may be wrong
- Improved Extended Tracking warning message to better explain what gets turned off
v2.20 June 4th, 2018
New
- Increased font size for the current UI selection
- New Bluetooth widget now provides more information about the connection status
- Added time of day to old messages sent within the same calendar year
- Added hot and cold indicators for situations where the battery is not charging due to high or low temperatures
- Device now triggers a mailbox check once an hour if it has not received any traffic
- Reduced battery requirements for flashing firmware
- Added Activation widget (only shows on deactivated devices)
Fixes
- Low battery notifications should now clear when the device is plugged in and charging
- Adjusted volume controls and resolved issues with certain sounds
- Removed some periods from being shown incorrectly on text strings
- Selecting Mute All will override "Ring Until Read" if the device is currently ringing
- Fixed rare issue with some messages not showing up in the thread overview
- Solved issue where the Weather page could show too many rain icons during light or no precipitation
- Fixed a few cases where Navigation alerts were missing
