请选择您的设备来获取相应的信息
此文章暂不支持您所选语言,请重新选择其他语言。
The Time on My vivoactive Is Not Correct
A vivoactive displays the time that is shown on your paired smartphone with the Garmin Connect app or from a personal computer using Garmin Express. If the time on your watch is not correct after you have completed a sync with either of these programs, this would indicate that the time setting on the watch is set to Manual instead of Auto.
Set Time to Auto:
Select the Action key (right side).
Select Settings.
Select System.
Select Clock.
Select Set Local Time.
Select Mobile Device (auto).
- Sync the device to save changes.
If the time is still not correct after syncing to Auto, you will need to acquire GPS by starting a timed activity. For details please see Acquiring Satellite Signals.
