You are viewing an article that is not available in your currently selected language. You can choose another one below.
Battery Specifications For Vector and Vector 2 Power Pedals
When replacing the batteries for your Vector power meter, it is recommended to replace batteries for both sides. Replacing just one battery may result in an uneven schedule for changes moving forward as one side may run low compared to the other.
  • CR2032, one for each pedal pod.
  • Up to 175 hours of battery life1.
1 Battery life is with cycling dynamics enabled and riding in normal riding temperatures, life can be extended if cycling dynamics are disabled. Cold temperatures can reduce battery life.
Příbuzný
