Editing Reps on the vivosmart 3
Using the Rep Counting feature the vivosmart 3 can track common gym exercises and count the number of reps completed.  The devices use consistent motion categorize exercises and display reps on the device.
Since each person’s form and exercise cadence is different it is possible that the vivosmart 3 may miss or count extra reps.  In these situations, the band allows for the number of reps to be edited directly on the band during rests between sets.
To edit reps on the vivosmart 3:
  1. Start the timer using the Strength Training app
  2. Complete the first set
  3. Tap the arrow
  4. Swipe and tap “Edit Reps”
  5. Use the arrows to add or remove reps
  6. Tap the number to confirm
  7. Swipe unit the Rest Timer is visible and tap the arrow to continue sets
  8. Repeat steps for each set as needed
These steps will ensure that the correct number of reps are displayed on the device and are synced to Garmin Connect.  The number of reps per set can also be edited in Garmin Connect after the activity is synced.
Note: While tracking a Strength Training exercise it is common for the device to not display any reps counted until the device tracks up to 5 reps.  In this situation you will see “—“ displayed on the band until the device recognizes between 3-5 reps.
