SPECS | BC 50 / BC 50 WITH NIGHT VISION | BC 40 | BC 35 | BC 30 | BC 20 | Garmin babyCam |
Receiver / Transmitter | Wi-Fi between GPS and Camera cable transmitter | Wi-Fi between GPS and Camera | Wi-Fi between GPS and Camera cable transmitter | Cable has receiver / Camera cable has transmitter | Mount has receiver / Camera cable has transmitter | Cable has receiver / Camera cable has transmitter |
Pair Multiple Cameras | Up to 4 | Up to 4 | Up to 4 | Up to 4 | 1 | Up to 4 |
Physical Dimensions (w x h x d) | BC 50: 1.0" x 0.9" x 0.7" (2.5 cm x 2.2 cm x 1.7 cm) BC 50 w/ Night Vision: 1.7" x 0.9" x 0.7" (4.3 cm x 2.2 cm x 1.9 cm) | 15.85 cm x 2.18 cm x 2.49 cm | 3.0 cm x 2.6 cm x 2.8 cm | 3.0 cm x 2.6 cm x 2.8 cm | 3.0 cm x 2.6 cm x 2.8 cm | 8.65 cm x 3.99 cm x 4.37 cm |
Weight | BC 50: 1.3 oz. (37.4 g) BC 50 w/ Night Vision: 1.8 oz. (51.2 g) | 2.08 oz (58.9 g) | 8.3 oz. (235 g) | 6.46 oz. (183 g) | 6.46 oz. (183 g) | 1.87 oz. (53.0 g) not including batteries |
Camera Water Rating | IP67 | IPX7 | IPX7 | IPX7 | IPX7 | N/A |
Resolution | Up to 720p 0.9MP | Up to 1280x720p 0.9MP | 640 X 480p 0.4MP | 240p 0.1MP | 640 x 480p 0.4MP | 640 x 480p 0.4MP |
Field of View | 160 degrees | 160 degrees | 160 degrees | 140 degrees | 170 degrees | 81 degrees |
Frame Rate | Up to 30 FPS | Up to 15 FPS | Up to 15 FPS | Up to 15 FPS | Up to 15 FPS | 30 FPS |
Ability to Flip Video Feed | Yes | Yes | Yes | N/A | N/A | Yes |
Transmission Distance | Up to 50 feet | Up to 26 feet | Up to 45 feet | Up to 45 feet | Up to 45 feet | N/A |
Camera Cable Length | 75” (190.5 cm) | N/A | 59.1” (150 cm) | N/A | N/A | N/A |
Wireless Transmitter to Camera Cable Length | 39.5” (100.3 cm) | N/A | 31.5” (80 cm) | N/A | N/A | N/A |
Wireless Transmitter to Vehicle Power Cable Length | 140” (355.6 cm) | N/A | 140” (355.6 cm) | N/A | N/A | N/A |
Transmitter to Splitter | N/A | N/A | N/A | 18" | 18" | N/A |
Splitter to Camera | N/A | N/A | N/A | 48" | 48" | N/A |
Splitter to End of Wires | N/A | N/A | N/A | 118" | 118" | N/A |
Optional Extension Cable | 50' (15.24 m) | N/A | N/A | 50' (15.24 m) | 50' (15.24 m) | N/A |
Night Vision IR illumination | BC 50 with Night Vision model only | N/A | N/A | N/A | N/A | N/A |
Differences Between Garmin Backup Cameras and Compatibility
Garmin's Backup Cameras:
Garmin Backup Camera Differences Table
NOTE: Update your device software by following the Software section under your device in Support Center to receive full functionality with the BC 50 series, BC 40, BC 35, BC 30, BC 20, and babyCam.
Backup Camera and Device Compatibility:
BC 50 and BC 50 with Night Vision Wireless Backup Cameras
The BC 50 and BC 50 with Night Vision wireless backup cameras are compatible with:
Camper 795 | RV 795 navigator
Camper 895 | RV 895 navigator
Camper 1095 | RV 1095 navigator
CamperCam 795 | RVcam 795 Navigator with Built-in Dash Cam
CamperVan caravan and motorhome sat nav
dēzl™ LGV610 | dēzl™ OTR610 GPS navigators
dēzl™ LGV620 | dēzl™ OTR620 GPS navigators
dēzl™ LGV710 | dēzl™ OTR710 GPS navigators
dēzl™ LGV720 | dēzl™ OTR720 GPS navigators
dēzlCam™ LGV710 | dēzlCam™ OTR710 GPS navigators with camera
dēzlCam™ LGV725 | dēzlCam™ OTR725 GPS navigators with camera
dēzl™ LGV810 | dēzl™ OTR810 GPS navigators
dēzl™ LGV820 | dēzl™ OTR820 GPS navigators
dēzl™ LGV1010 | dēzl™ OTR1010 GPS navigators
dēzl™ LGV1020 | dēzl™ OTR1020 GPS navigators
Garmin Drive™ 53 & Live Traffic GPS navigator
Not compatible on North American devices.
Garmin DriveCam™ 76 GPS navigator with camera
Garmin DriveSmart™ 66 | Garmin DriveSmart™ 76 | Garmin DriveSmart™ 86 GPS navigators
Arctic Cat G8 Display | Kawasaki RIDGE 8" Tread Display | Tread® | Tread® - Base Edition | Tread® 2 | Tread® 2 - Overland Edition | Tread® 2 - SxS Edition | Tread® - Overland Edition | Tread® XL - Overland Edition | Tread® - SxS Edition | Tread® XL - Baja Chase Edition | Tread® XL - Baja Race Edition GPS navigators
zūmo® XT2 GPS navigator
BC 40 Wireless Backup Camera
The BC 40 wireless backup camera is compatible with the Garmin GPS navigators below, provided the operating range between them does not exceed 26 feet (7.93 meters). This range can be further reduced by certain environmental factors. See Environmental Interference with the BC 40:
Camper 770 and RV 770 GPS navigators¹
Camper 780 and RV 780 GPS navigators¹
Camper 795 and RV 795 GPS navigators¹
CamperCam and RVcam 795 GPS navigators with camera¹
CamperVan caravan and motorhome sat nav¹
dēzl™ LGV500 | dēzl™ OTR500 GPS navigators¹
dēzl™ LGV610 | dēzl™ OTR610 GPS navigators¹
dēzl™ LGV700 | dēzl™ OTR700 GPS navigators¹
dēzl™ LGV710 | dēzl™ OTR710 GPS navigators¹
- dēzlCam™ LGV710 | dēzlCam™ OTR710 GPS navigators with camera¹
Garmin Drive™ 53 & Live Traffic GPS navigator¹
Garmin Drive™ 55 & Live Traffic GPS navigator¹
Garmin DriveAssist™ 51 LMT-S GPS navigator with camera¹
Garmin DriveCam™ 76 GPS navigator with camera¹
Garmin DriveSmart™ 7 LMT EX | Garmin DriveSmart™ 7 LMT-S EX | Garmin DriveLuxe™ 51LMT-S | Garmin DriveSmart™ 51LMT-S | Garmin DriveSmart™ 55 & Traffic | Garmin DriveSmart™ 61LMT-S | Garmin DriveSmart™ 65 & Traffic | Garmin DriveSmart™ 65 with Amazon Alexa | Garmin DriveSmart™ 66 | Garmin DriveSmart™ 71 EX | Garmin DriveSmart™ 76 | Garmin DriveSmart™ 86 GPS navigators¹
Garmin DriveTrack™ 71 GPS navigator¹
Tread® | Tread® - Base Edition GPS navigators¹
zūmo® XT | zūmo® XT2 GPS navigators¹
BC 35 Wireless Backup Camera
The BC 35 wireless backup camera is compatible with:
Camper 785 | RV 785 & Traffic navigator
Camper 890 | RV 890 navigator
Camper 1090 | RV 1090 navigator
Garmin fleet™ 770 GPS management
Garmin fleet™ 780 GPS management
Garmin fleet™ 790 GPS management
dēzl™ 780LMT-S GPS navigator
dēzl™ LGV800 | dēzl™ OTR800 GPS navigators
dēzl™ LGV1000 | dēzl™ OTR1000 GPS navigators
dēzlCam™ 785 GPS navigator with camera
Overlander® GPS navigator
RV 701 Navigator and Remote
BC 30 Wireless Backup Camera
The BC 30 wireless backup camera is compatible with:
Camper 660LMT | RV 660LMT navigator
Camper 770LMT-D | RV 770LMT-S navigator
Camper 780 & Traffic | RV 780 & Traffic navigator
dēzl™ 570 LMT GPS navigator
dēzl™ 580 LMT-S GPS navigator
dēzl™ 770LMTHD GPS navigator
dēzlCam™ LMTHD GPS navigator with camera
Garmin Drive™ 5 | Garmin Drive™ 5LM | Garmin Drive™ 5LM EX | Garmin Drive™ 5LMT GPS navigators
Garmin Drive™ 6 GPS navigator
Garmin Drive™ 40 GPS navigator
Garmin Drive™ 50LM | Garmin Drive™ 50LMT GPS navigators
Garmin Drive™ 60LM | Garmin Drive™ 60LMT GPS navigators
Garmin Drive™ 51| Garmin Drive™ 51EX | Garmin Drive™ 51LM GPS navigators
Garmin Drive™ 52EX | Garmin Drive™ 52M | Garmin Drive™ 52MT | Garmin Drive™ 52MT-S GPS navigators
Garmin Drive™ 61| Garmin Drive™ 61EX | Garmin Drive™ 61LMT-S GPS navigators
Garmin DriveAssist™ 50 GPS | Garmin DriveAssist™ 51 GPS navigators with camera
Garmin DriveLuxe™ 50 | Garmin DriveLuxe™ 51 GPS navigator
Garmin DriveSmart™ 7 LMT EX | Garmin DriveSmart™ 7 LMT-S EX | Garmin DriveSmart™ 51LMT-S | Garmin DriveSmart™ 55 & Traffic | Garmin DriveSmart™ 61LMT-S | Garmin DriveSmart™ 65 & Traffic | Garmin DriveSmart™ 65 with Amazon Alexa | Garmin DriveSmart™ 66 | Garmin DriveSmart™ 71 EX | Garmin DriveSmart™ 76 | Garmin DriveSmart™ 86 GPS navigators
Garmin DriveTrack™ 70 GPS navigator
nüvi® 55 | nüvi® 55LM | nüvi® 55LMT | nüvi® 56 |nüvi® 56LM | nüvi® 56LMT | nüvi® 57 | nüvi® 57LM | nüvi® 57LMT | nüvi® 58 | nüvi® 58LM | nüvi® 58LMT GPS navigators
nüvi® 65LM | nüvi® 65LMT | nüvi® 66 | nüvi® 66LM| nüvi® 66LMT | nüvi® 67 | nüvi® 67LM | nüvi® 67LMT | nüvi® 68LM | nüvi® 68LMT GPS navigators
nüvi® 2407 | nüvi® 2447 | nüvi® 2457 | nüvi® 2467 | nüvi® 2497 GPS navigators
nüvi® 2408 | nüvi® 2418 | nüvi® 2448 | nüvi® 2468 | nüvi® 2498 GPS navigators
nüvi® 2507LMT | nüvi® 2517LMT | nüvi® 2547LMT | nüvi® 2557LMT | nüvi® 2577LT | nüvi® 2597LMT
nüvi® 2508 | nüvi® 2518 | nüvi® 2548 | nüvi® 2558LMTHD | nüvi® 2568 | nüvi® 2598LMTHD GPS navigators
nüvi® 2519LMT | nüvi® 2529LMT | nüvi® 2539LMT | nüvi® 2559LMTHD | nüvi® 2569LMT | nüvi® 2589LMT | nüvi® 2599LMT GPS navigators
nüvi® 2639LMT | nüvi® 2659LMT | nüvi® 2689LMT | nüvi® 2699LMTHD GPS navigators
nüvi® 2759LMT | nüvi® 2789LMT | nüvi® 2799LMT GPS navigators
nūviCam™ LMTHD GPS navigator with camera
BC 20 Wireless Backup Camera
Camper 760 | RV 760 navigator
dēzl™ 760 LMT GPS navigator
nüvi® 2798LMT with Backup Camera GPS navigator
Garmin babyCam In-Vehicle Video Baby Monitor
dēzl™ 570LMT GPS navigator
Garmin Drive™ 50 | Garmin Drive™ 60 GPS navigators
Garmin DriveAssist™ 50 GPS navigator with camera
Garmin DriveSmart™ 50 | Garmin DriveSmart™ 60 | Garmin DriveSmart™ 70 GPS navigators
nüvi® 2457LMT | nüvi® 2497LMT GPS navigators
nüvi® 2539LMT | nüvi® 2559LMT | nüvi® 2589LMT | nüvi® 2599LMT GPS navigators
nüvi® 2557LMT | nüvi® 2577LMT | nüvi® 2597LMT GPS navigators
nüvi® 2558LMTHD | nüvi® 2598LMTHD GPS navigators
nüvi® 2639LMT | nüvi® 2689LMT | nüvi® 2699LMTHD GPS navigators
nüvi® 2789LMT GPS navigator
nüviCam™ LMTHD GPS navigator with camera
Camper 660LMT caravan and motorhome sat nav | RV 660LMT RV navigator
NOTE: Devices are not able to receive audio from a third-party backup camera.
¹The operating range between the paired Garmin GPS navigator and the BC™ 40 wireless camera must not exceed 26 feet (7.93 meters).
