Du får vist en artikel, der ikke er tilgængelig på det valgte sprog. Du kan vælge et andet nedenfor.
How to Install Software Updates to My fēnix Watch
The software on fēnix® watches should be kept up-to-date in order to take advantage of improvements and bug fixes. Updates are free, and easy to install. Software updates can be installed through the Garmin Express™ program.
Garmin ExpressThe Garmin Express program provides the ability to check for software updates automatically each time the device is connected to a computer. For information on downloading and installing Garmin Express software, follow the link below. How Do I Install Garmin Express |
Updating the fēnix Software Through Garmin Express
IMPORTANT: If this is your first time using a computer with your watch, you will need to download and install Garmin Express™ software.
- Connect your watch to your computer with the USB charging cable.
- Launch the Garmin Express program.
- Select your watch.
- NOTE: If this is your first time using the Garmin Express program, see - Adding and Removing Devices in Garmin Express.
- The Garmin Express program will then display the available updates. Select Install or Install All.
- Review and accept any prompts for Terms and Conditions or Important Notes.
- Once complete, disconnect your device from the computer and the watch will ask if you want to "Install Now" or "Install Tonight". If you do not receive this prompt, or if you select "Install Tonight", you can still access the update from the System menu on the watch:
- From the main menu on the watch, select or scroll to Settings.
- Select System.
- Select Software Update.
- Select Update Available.
My Garmin Watch is Not Recognized by Garmin Express Software
- Recognized by the computer but not by Garmin Express program:
- Not recognized by the computer and not by Garmin Express program:
If you are having difficulty with this process, search the Support Center with "Garmin Express" identified as the product for further troubleshooting assistance.
