Using the Hydration Widget or Glance on Your Garmin Watch
Select models are compatible with the Garmin Hydration Tracking widget glance which can be downloaded through the Connect IQ™ app, if not already installed. There are two different hydration tracking widgets offered by Garmin, so be certain to download the widget glance that is compatible with your watch.
NOTE: If you are using the Connect IQ app and your watch is paired to the app, it will automatically provide you with the correct compatible widget or app when you search for hydration tracking.
Steps on Adding Fluid Intake:
Swipe through the touchscreen or press the DOWNkey to navigate to the Hydration widget or glance on your watch. Select + or - to increase or decrease your fluid tally, or use the custom container sizes to add that preset amount to your total.
It may be necessary after opening the widget or glance, to press the top right button to access the screen for adding fluid intake. The amounts for preset containers can be adjusted in the settings for the widget or glance, see the instructions below.
Compatible Watches and How to Customize Settings:
The Hydration Tracking widget or glance downloaded from the Connect IQ Store allows for setting the units of measure for fluids, automatic hydration goals, hydration alerts, and custom container sizes. To view instructions for accessing these settings, select your device below:
Approach® Watches
The directions below will work for the following watches:
Approach® S70 - 42mm | Approach® S70 - 47mm
Swipe up to navigate to the Hydration widget glance.
Touch the Hydration widget glance.
Press Menu to open the menu.
Select an option:
To change the units of measure, select Units.
To enable dynamic daily goals that increase after recording an activity, select Auto Increase Goal.
To turn on hydration reminders, select Alerts.
To customize your container sizes, select Containers, select a container, select the units of measure, and enter the container size.
D2™ Watches
D2™ Air
D2™ Air X10
Swipe to view the Hydration widget.
Hold the bottom right button to access the widget settings.
Select an option:
D2™ Mach 1
Press DOWN (lower left button) to navigate to the Hydration widget glance.
If needed press START (top right button) to open the widget or glance.
Press and hold UP (middle left button) to open the menu.
Select an option:
Descent™ Watches
Descent™ G1 | Descent™ G1 Solar
Descent™ Mk2S watch and all other models in the Descent Mk2 series
Select an option:
Enduro™ Watches
Enduro™
Enduro™ 2
Select an option:
epix™ Watches
All other hydration settings can only be customized in Garmin Connect. For details see, .
Syncing Hydration to Garmin Connect:
If you notice an inconsistency in your fluid intake data between your watch's hydration widget and Garmin Connect, please follow these steps to get the values to sync up:
Navigate to the hydration widget or glance on your watch.
Swipe down on the screen to refresh and see the updated data from the watch.
How to Identify and Update the Hydration Software Version:
If you have any issues with your Hydration Widget syncing or updating fluid intake after following the steps mentioned above, it may be necessary to check for a pending software update to the Hydration Widget.
