Using the Group Ride App on the Tread
The Group Ride App on the Tread allows you to coordinate rides and communicate with nearby riders using preset text messages and live map locations.
  • Up to 20 riders can join a Group Ride
  • Icons for other vehicles will be visible on the map screen as you ride
    • Rider colors cannot be changed
    • Group Ride leader is blue
    • Other rider colors are randomly assigned
  • Users should be close together (within Wi-Fi range) when setting up a Group Ride
    • New riders can be added by any nearby member of the group once a Group Ride has started
    • Group members will be alerted a new rider has joined once they are in radio range of the new rider
  • Range performance varies based on terrain and other line-of-sight limitations
  • The Tread must be mounted with the antenna properly installed before starting a Group Ride
  • The default map view for Groups Rides is "Auto Zoom to Group"
    • The map will automatically zoom in and out based on the location of active riders
    • See the Owner's Manual for instructions to adjust the map view for Group Rides
See the detailed video below for instructions to set up a Group Ride.
