Calibrating the MSC 10
Calibration of the MSC-10 is done in a similar fashion to other NMEA 2000 heading sensors (GPS 24xd, 9-axis Compass, etc.), accessed via the MFD Communications Menu:
Select Settings > Communications > NMEA 2000 Setup > Device List
Select the MSC 10 from the device list
Select Review > Compass Cal. > Begin
Follow the on-screen instructions until the compass calibration is complete
MSC 10 Basic Calibration
When performing basic calibration, first calibrate the compass and then align the heading in one continuous procedure.
Note: The boat must be able to reach a cruising speed of at least 6.4 km/h (4 mph) to perform the heading alignment.
Drive the boat to a location with calm, open water
Set the display to view heading data from the connected compass
NOTE: Do not use GPS Course Over Ground (COG) to perform basic calibration
Disconnect the compass from the NMEA 2000 network or turn off the power to the NMEA 2000 network
Wait while the boat becomes level and stationary
Turn on power to the compass and wait until the heading data appears on the display
NOTE: If this is the first basic calibration after a factory reset, the heading is blank
Within three minutes, complete two full slow, tight circles taking care to keep the boat as steady and level as possible; the boat should not list during calibration
Continue turning in the same direction at the same speed for approximately one and a half rotations until the heading data appears. When the heading data appears, the compass has been calibrated successfully and you can align the heading (optional)
Select an option:
To align the heading to match the front pf the boat, proceed to the next step
If choosing to not align the heading, stop turning and wait, keeping the boat stationary. Over the next two minutes the heading data should disappear and then reappear. When the heading data reappears, the compass should be calibrated and no heading offset should be applied
NOTE: If an unwanted heading offset is applied, repeat the calibration procedure
Continue turning in the same direction at the same speed for approximately ten seconds, until the heading data disappears from the display
When it is safe, straighten the boat and drive in a straight line at cruising speed (must be at least 6.4 km/h (4 mph)) until the heading data appears; when the heading appears, the compass has been calibrated, and the heading has been aligned
Test the results of the calibration, and repeat this procedure if necessary
