Replacing an Approach S10 Watch Band
If the band for your Approach S10 is starting to look worn, has broken, or you just got a new watchband, this article will help you replace the old band and purchase a new band.
Replacing the Band
Replacing the band on your Approach S10 takes just a few steps. Before getting started, watch this video to see the process in action:
Tools Needed
- A T5 Torx driver (provided when purchasing a replacement band from Garmin.com)
Removing the Band
- Locate the screws on the inside of the band by the watch housing
- Use the torx screwdriver to remove the screws
- Pull the watchband away from the housing
The band can now be replaced.
Replacing the Band
- Push the replacement band into place, you should hear a click
- Use the torx screwdriver to screw the screws back into place
You have now successfully replaced your band.
Purchasing a Replacement
If the band on your Garmin golf wearable needs to be replaced because it has broken, torn or otherwise become unusable, replaceable bands can be purchased on our website using the link below, then selecting Bands.
If the above link does not work for you, follow these steps to locate replacement bands on at Garmin.com:
- Go to Garmin.com
- Hover over the Products menu at the top of the screen
- Hover over Sports & Fitness
- Select Golf
- Select your device from the list*
- Click Accessories
- Click Bands
You will now see a list of compatible bands for your Approach.
*If your device is not listed here you may need to use the search box located in the upper right-hand corner of the Garmin.com home page.
