Auto Calibration On
Setting auto calibration to On calibrates the sensor at the start of an activity. This will provide a consistent relative starting elevation if you do multiple activities at specific locations. When the timer is started the watch will try to determine the best elevation source to calibrate to, based on the following priority:
- Manual calibration immediately prior to starting the activity.
- Prior manual calibration point at the same location.
- Recent manual calibration, if the quality of the calibration is determined to be good enough.
- Map data (DEM - Digital Elevation Map), if available.
- Prior Connected DEM point at the same location:
- Connected DEM refers to elevation data from the Garmin Connect app on a paired smartphone.
- Connected DEM, if currently connected to a phone.
- Prior GPS point at the same location.
- GPS, if a good fix has been acquired:
- After acquiring a GPS fix the timer ring will turn yellow. At that point, it can take up to 30 seconds for the GPS elevation to settle. If vertical speed settles to less than .1 m/s the GPS elevation data will be considered good enough use for altimeter calibration.
Before starting the timer, the elevation data field on the watch will preview the calibrated elevation.
Throughout the activity, the watch uses DEM mapping data, and GPS elevation to make adjustments to altitude for any altimeter drift due to pressure changes caused by a weather event during an activity.
Auto Calibration Nightly
Setting auto calibration to Nightly will calibrate the altimeter once every night during your sleep window set in Garmin Connect. If paired, the Garmin Connect app uses location data from the phone and compares it to the DEM information of the watch. This allows the nightly calibration feature to work better but is not required.
- When starting an activity, the watch will show current calibration and give the options to accept, or recalibrate.
- Nightly calibration is also performed when auto calibration is set to On.
