How to Connect the Garmin Golf App to E6 Connect on PC
E6 Connect is a third party service available for you to simulate rounds of golf with your Approach R10. You will be able to play virtual rounds using photorealistic courses from home whenever you want.
Requirements
Connecting to E6 Connect
Select one of the two E6 Setup experiences to begin.
Is This Your First Time Using E6 Connect?
Follow the below instructions if this is your first time opening E6 Connect Software on your computer.
  1. Open the E6 Connect software on your computer.
  2. Complete the first time setup to login to the software.
  3. Select Simulator.
  4. Select Tracking System.
  5. Select Garmin.
  6. Select Configure.
  7. Select the listed IP Address (ex. 192.16.8.1.xx), under HOST.
  8. In the Garmin Golf app, select More (iOS) or Menu Icon (Android).
  9. Select Golf Sim.
  10. Select TruGolf E6 Connect.
  11. Select Play on PC.
  12. Select Enter Host & Port Info.
  13. Enter the IPv4 address into the Host field.
  14. In the E6 Connect software, select Accept.
  15. In the Garmin Golf app, touch Test Connection.
Are You an Existing E6 Connect Customer?
Follow the below instructions if you already have E6 Connect Software setup on your computer.
  1. Open the E6 Connect software, select Settings.
  2. Select Simulator.
  3. Select Tracking System.
  4. Select Garmin.
  5. Select Configure.
  6. Select the listed IP Address (ex. 192.16.8.1.xx), under HOST.
  7. In the Garmin Golf app, select More (iOS) or Menu Icon (Android).
  8. Select Golf Sim.
  9. Select TruGolf E6 Connect.
  10. Select Play on PC.
  11. Select Enter Host & Port Info.
  12. Enter the IPv4 address into the Host field.
  13. In the E6 Connect software, select Accept.
  14. In the Garmin Golf app, touch Test Connection.
Troubleshooting the Connection to E6 Connect
If you are running into issues with your connection, select one of the below to determine how to fix it.
Error Message, "Connection Failed. Please make sure your E6 Connect software is running"
Setting Your Network Profile to Public
Setting your network profile to public will help resolve this error.
  1. Click on the Wi-Fi connection icon in the lower right corner of the System Tray of your computer.
  2. Click Properties under the connection status.
  3. Click Private under Network Profile.
After changing the network profile setting, open TruGolf E6 Connect from the Garmin Golf app to start playing.
Other Connection Issues
If you are experiencing other connection issues, check the following:
  • The mobile device running the Garmin Golf app needs to be on the same Wi-Fi network as the computer running the E6 Connect software.
  • Be sure that you have the latest version of E6 Connect.
  • Disable your Virtual Private Network (VPN) if you are connected to one.
  • Check for firewalls or other custom configurations which could block the communication.
  • Disable any virtual machines running on the PC.
