Approach S70 Series Battery Life Assumptions
The battery life of your Garmin™ watch may be affected by how you use the watch. The information below is presented as a general guide for reference only on Approach® S70 golf watches. All default software settings and configurations are assumed for the battery life specifications.
Battery Life Specifications with Default Settings
    • Approach® S70 - 42mm
      • Smartwatch mode: Up to 10 days
      • GPS Mode Up to 15 hours (using default display settings: gesture wake-up in Smartwatch mode and always-on while golfing)
    • Approach® S70 - 47mm
      • Smartwatch mode: Up to 16 days
      • GPS Mode Up to 20 hours (using default display settings: gesture wake-up in Smartwatch mode and always-on while golfing)
Usage Factors That Impact Battery Life
  • Approach S70 watches use an ambient light sensor to automatically adjust the display brightness to an acceptable level depending upon the level of ambient light. Using the watch outdoors in bright environments may reduce battery life.
  • Changes to the default display settings can significantly impact battery life. Higher screen usage will generally result in less battery life.
Tips for Maximizing Battery Life
