Du får vist en artikel, der ikke er tilgængelig på det valgte sprog. Du kan vælge et andet nedenfor.
How to Search, Save, Edit, or Delete Locations on an Automotive Device
Choose a topic below for instructions on searching for, saving, editing, or deleting addresses or points of interest (POI).
A Detailed Video Walkthrough can be Found Below:
To Search for an Address
1. Touch Where To?
2. Touch Address
3. Follow the on-screen instructions to enter address information
4. Select Searching in to change the city/state or location if necessary
The address should appear in the list of search results. Select the desired destination from this list and touch Go.
To Search for a Point of Interest
1. Touch Where To?
2. Touch Categories
3. Select the POI category (food, fuel, lodging, etc.) best matching your desired destination
4. Select a subcategory if necessary
5. Select the destination from the listed nearby POIs
6. Touch Go to calculate a route once you have selected the destination
Destinations can be saved so they can be easily accessed in the future. The destination will then be accessible from Favorites or Saved in the Where To? menu on the device. See below for instructions on saving results.
To Save a Result
1. Search for an address, POI, etc, using the options available in the Where To? menu
2. Select a location from the search results
3. Touch the  info button
  • Skip this step on some devices
4. Touch Save (you may need to first touch the  menu button)
5. Touch Save
6. Enter a name for the location if prompted
7. Touch Done if prompted
8. Touch OK when notified the address has been added to Saved Places
Repeat steps to save additional destinations.
To Edit a Favorite
1. Touch Where To?
2. Touch Favorites or Saved
3. Touch the favorite you would like to edit
4. Touch the  info button
5. Touch the  menu button
6. Touch Edit
7. Touch the information you would like to change
  • You may change the name, phone numbercategories, and map symbol assigned to the location
Touch and hold the back arrow to return to the main menu.
To Delete a Favorite
1. Touch Where To?
3. Locate and touch the favorite you would like to delete
  • Some devices require you to touch the Info button (lower-case i) after this step
4. Touch the menu button (three lines) in the upper-left of the screen
5. Touch Delete
6. Touch Yes
The selected favorite(s) will now be deleted.
To Delete Multiple Favorites:
1. Touch Where To?
3. Touch menu button (three lines) in the upper left corner
4. Touch Delete Favorites or Delete Saved Places
5. Touch the location(s) you would like to delete
  • Touch Select All if you would like to delete all saved favorites
6. Touch Delete once the desired locations are selected
7. Touch Yes
