NMEA 2000 PGN data
NMEA 2000 is a standardized plug-and-play communications standard used for connecting marine sensors and display units aboard boats. Below is a partial list of NMEA 2000 PGN's. For the Garmin unit specific NMEA 2000 PGN list, see the unit's installation manual. For specific descriptions of NMEA 2000 PGN's not listed below, go to the NMEA 2000 PGN Search Page, here. Some third-party manufacturers list devices as NMEA 2000 compatible or NMEA 2000 compliant which is not the same as NMEA 2000 Certified and may not be fully compatible with NMEA Certified devices such as Garmin GPSMAP units.
PGN 059392 - ISO Acknowledgement
PGN 059904 - ISO Request
PGN 060928 - ISO Address Claim
PGN 126996 - Product Information
PGN 127250 - Vessel Heading
Heading Sensor Reading
PGN 127488 - Engine Parameters, Rapid Update
Generic Instance (0-3, we will support up to 4 engines)
Engine Speed
Engine Tilt/Trim
PGN 127489 - Engine Parameters, Dynamic
Engine Oil Pressure
Engine Temperature
Alternator Potential
Total Engine Hours
PGN 127505 - Fluid Level
Generic Instance
Fluid Type
0x00 Fuel (we will not support other fluid types)
Tank Capacity
PGN 128259 - Speed
Water Speed Referenced
PGN 125267 - Water Depth
Water Depth, Transducer
PGN 129039 - AIS Class B Position Report
Will support the same information that we do for NMEA 0183
PGN 129040 - AIS Class B Extended Position Report
PGN 129808 - DSC Call Information
PGN 130306 - Wind Data
Wind Speed
Wind Direction
Wind Reference
PGN 130310 - Environmental Parameters
Water Temperature
PGN 130569 - Entertainment - Current File Status
PGN 130570 - Entertainment - Library Data File
PGN 130571 - Entertainment - Library Data Group
PGN 130573 - Entertainment - Supported Source Data
PGN 130574 - Entertainment - Supported Zone Data
NOTE: Entertainment PGN are only supported on 2016 and newer GPSMAP chartplotters.
