Setting Up Garmin Pay on Edge 1050
You can use your Edge® 1050 cycling computer to make contactless payments with a compatible bank card
The initial set up of Garmin Pay requires the edge to be paired to the Garmin Connect™ App. For steps to pair with your phone, see Pairing Your Phone.
  1. Select More.
  2. Select Garmin Pay.
  3. Select Get Started.
  4. Select the Edge 1050.
  5. Select Next.
  6. Create and confirm a Passcode.
  7. Read the Terms & Conditions and select Continue
  8. Enter the Card information and select Next.
  9. Select a current billing address or select Add a New Address+.
    • Enter address and select save if entering a new one.
  10. Select Next.
  11. Select the card in order to verify it.
  12. Under Not Enabled, select the Edge 1050 Pending Verification.
  13. Select a method to verify your identity
  14. Enter the code.
  15. Select Send.
Adding Another Card to Your Garmin Pay Wallet
NOTE: You can add up to 10 cards to your Garmin Pay wallet.
  1. From the Garmin Connect App, select More (bottom right).
  3. Select plus sign in app .
  5. Select Next and follow the on-screen instructions.
Using Garmin Pay
  1. Select 1050 menu icon .
  3. Enter your 4 digit passcode.
    NOTE: if you enter your passcode incorrectly 3 times, your wallet locks and you must reset your passcode in the Garmin Connect App.
  4. If you have added multiple cards to your Garmin Pay wallet, you can swipe to change to another card in this step.
  5. Within 60 seconds, hold your Edge near the payment reader, with the Edge facing the reader.
    The edge will vibrate and display a check mark when it is done communicating with the reader.
Managing Cards
NOTE: In some countries, some financial institutions map restrict the Garmin Pay Features.
  1. From the Garmin Connect app, select More (bottom right).
  3. Select a card.
  5. Select an option:
    • Suspend Card
    • Remove Card
Relaterede
