"Pin exceeds maximum range...." Message During Calibration
During the calibration process of the XeroTM bow sight the "Pin exceeds maximum range for your setup. Use shorter range." message occurs when there is no more room for the LED pin to travel down the sight display.
There are two options for this scenario:
- Calibrate to a shorter range
- Choose the custom top pin placement option and/or change your mount setup regarding the vertical bar* if possible.
- For more information on custom top pin placement review the related content at the bottom of the page
*When adjusting the vertical bar of the bow sight mount ensure to check broadhead clearance before firing
