Setting an Abnormal Heart Rate Alert on a Garmin Watch
Many Garmin watches can notify you with an alert when your heart rate goes above or below a specified level when you are not active. Inactivity occurs after the watch does not detect movement such as steps for a minimum of 10 minutes. The type of alert depends on the options available on your watch. If your watch can vibrate and sound a tone for other notifications, then those options will be available for abnormal heart rate alerts as well. See your owner's manual for more information.
IMPORTANT: Garmin watches are not medical devices. Heart rate data is not intended to be used for medical purposes, nor is it intended to diagnose, treat, cure, or prevent any disease or condition. This feature only alerts you when your heart rate exceeds or drops below a certain number of beats per minute, as selected by the user, after a period of inactivity. This feature does not notify you of any potential heart condition and is not intended to treat or diagnose any medical condition or disease. Always defer to your health care provider for any heart-related issues.
For instructions to set an Abnormal Heart Rate Alert, select your product from the list below.
Approach® S70 Watches
  1. Press and hold the bottom right button to access your settings menu.
  2. Select Settings Gear.
  3. Select Wrist Heart Rate.
  4. Select Abnormal HR Alert.
  5. Turn on Low Alert or High Alert with the slider on the right side.
  6. Set the heart rate threshold by selecting the value displayed.
D2 Watches
D2 Air
D2 Air X10
D2 Delta | D2 Delta PX | D2 Delta S
  1. Hold UP/MENU.
  2. Select Settings.
  3. Select Sensors & Accessories
  4. Select Wrist Heart Rate
  5. Select Abnormal Heart Rate Alert
  6. Press START/STOP to turn Status to On.
  7. Set the heart rate Alert Threshold.
D2 Mach 1
  1. Hold UP/Menu.
  2. Select or scroll to Settings.
  5. Select Abnormal Heart Rate Alerts
  6. Press START/STOP to turn on High Alert or Low Alert
  7. Set the heart rate threshold.
Descent Watches
Descent G1 | Descent G1 Solar
  1. Hold UP/Menu.
Descent Mk1
  1. Hold UP/Menu.
  2. Select Settings.
Descent Mk2 | Descent Mk2S | Descent Mk2i
  1. Hold UP/Menu.
  2. Select Settings.
Enduro™ | Enduro™ 2
  1. Hold UP/Menu.
  2. Settings.
epix Watches
epix (Gen 2) | epix (Gen 2) Sapphire | epix Pro (Gen 2) Standard | epix Pro (Gen 2) Sapphire
  1. Hold UP/Menu.
  2. Select Settings.
fēnix® Watches
fēnix 5
NOTE: Not compatible with low heart rate alerts.
  1. Hold UP/Menu.
  2. Select Settings.
  3. Select Sensors & Accessories.
  4. Select Wrist Heart Rate.
  5. Select Abnormal Heart Rate Alert.
fēnix 5 Plus and All Other Watches in the fēnix 5 Series
  1. Hold UP/Menu.
  2. Select Settings.
fēnix 6 Standard and All Others in the fēnix 6 Series
  1. Hold UP/Menu.
  2. Select Settings.
fēnix 7 Standard and All Others in the fēnix 7 Series
  1. Hold UP/Menu.
  2. Select Settings.
fēnix 7 Pro - Solar and All Others in the fēnix 7 Pro Series
  1. Hold UP/Menu.
  2. Select Settings.
Forerunner® Watches
Forerunner 45 | Forerunner 45S
  1. Hold the Up key until the menu opens.
  2. Select Wrist Heart Rate.
  3. Select Abnormal Heart Rate Alerts.
  4. Turn on High Alert.
  5. Set the high heart rate threshold.
  6. Repeat for the Low Alert.
Forerunner 55
Forerunner 245 | Forerunner 245 Music
Forerunner 255 | Forerunner 255S |Forerunner 255 Music | Forerunner 255S Music
Forerunner 265 | Forerunner 265S | Forerunner 265 Music | Forerunner 265S Music
Forerunner 645 | Forerunner 645 Music
  2. Select Settings.
  4. Select Abnormal Heart Rate Alert.
  5. Set the Status to Auto.
  6. Set the Alert Threshold.
Forerunner 745
Forerunner 935
  2. Select Settings.
  6. Set the Status to Auto.
  7. Set the Alert Threshold.
Forerunner 945 | Forerunner 945 LTE
Forerunner 955 | Forerunner 955 Solar
Forerunner 965
Instinct® Watches
Instinct 2 Standard Edition and All Others in the Instinct 2 Series
  1. Hold UP/Menu.
  2. Select Settings.
  6. Press GPS to turn on High Alert or Low Alert
Instinct Crossover Standard Edition and All Others in the Instinct Crossover Series
  1. Hold UP/Menu.
  2. Select Settings.
Instinct Solar Standard Edition and All Others in the Instinct Solar Series
  1. Hold UP/Menu.
  2. Select Settings.
Instinct Standard Edition and All Others in the Instinct Series
  1. Hold UP/Menu.
Lily™ - Classic Edition | Lily™ - Sport Edition
  1. Press Circle to view the menu.
  2. Select Settings Gear Settings icon.
  3. Select the Heart icon with a gear in front Wrist HR icon.
  4. Select HR Alerts.
  5. Select High Alert or Low Alert.
  6. Set the heart rate threshold.
MARQ® Watches
  1. Hold UP/Menu.
quatix® Watches
quatix 5
NOTE: Not compatible with low heart rate alert.
  1. Hold UP/MENU.
  2. Select Settings.
quatix 6 | quatix 6X Solar | quatix 6 Titantium
  1. Hold UP/MENU.
tactix® Watches
tactix 7 Standard Edition | tactix 7 Pro Edition | tactix 7 Pro Ballistics
  1. Hold UP/Menu.
  2. Select Settings.
tactix Delta - Sapphire Edition | tactix Delta - Solar Edition | tactix Delta Solar Edition with Ballistics
  1. Hold UP/Menu.
  2. Select Settings.
Venu® Watches
Venu
  2. Select Settings Gear .
Venu 2 | Venu 2S | Venu 2 Plus
Venu 3 | Venu 3S
  2. Select Settings .
  3. Select Notifications & Alerts.
  4. Select Health & Wellness.
  5. Select Heart Rate.
  6. Turn on Low Alert or High Alert with the slider on the right side.
  7. Set the heart rate threshold by selecting the value displayed.
Venu Sq | Venu Sq Music Edition | Venu Sq 2 | Venu Sq 2 Music Edition
vívoactive® Watches
vÍvoactive 3 | vÍvoactive 3 Music | vÍvoactive 3 (Verizon)
  1. Press and hold the touchscreen.
  2. Select Settings.
  4. Select Heart Rate.
  5. Turn on Abnormal HR Alert with the slider to the right.
  6. Select Abnormal HR Alert
  7. Select Alert Threshold.
  8. Set the heart rate threshold.
vÍvoactive 4 | vÍvoactive 4S | Captain Marvel | First Avenger | Rey | Darth Vader
vívomove® Watches
vívomove HR
  1. Hold the touchscreen to view the menu.
  2. Select Heart Outline.
  3. Select Heart rate with exclamation point.
  4. Select a high heart rate threshold value.
  5. Tap the touchscreen to confirm the value.
vívomove 3 | vívomove 3S | vívomove Luxe | vívomove Sport | vívomove Style
  1. Press and hold the touchscreen to view the menu.
  3. Select Heart With Gear.
  4. Select Heart rate with exclamation point.
  5. Select Heart with up arrow (high alert) or Heart with down arrow (low alert).
  6. Tap the screen to turn on the toggle.
  7. Select the back arrow (left).
  8. Follow the on-screen instructions to set the heart rate threshold value.
  9. Tap the touchscreen to confirm the value.
vívomove Trend
  1. Double-tap the display to wake up your watch.
  2. Press and hold the touchscreen to view the menu.
  3. Select Settings Gear.
  4. Select Heart & Stress.
  5. Select Abnormal HR Alert.
  6. Select High or Low.
  7. Select On, if not already.
  8. When you see 'Set Threshold Now?' select Checkmark icon.
    1. High HR Alert: Select a value between 100 - 200 BPM
    2. Low HR Alert: Select a value between 40 - 60 BPM
  9. Select your High and Low values.
  10. Select the Checkmark icon to confirm.
  11. Allow the watch screen to timeout.
vívosmart® Watches
vívosmart 3
  2. Select Heart.
  3. Select Heart with exclamation point.
vívosmart 4
NOTE: You must also enable the alert on both your watch and in your Garmin Connect™ account. The threshold value can only be updated in the Garmin Connect app.
From the Watch:
  1. Press menu button to view the menu.
  2. Select Settings gear.
  4. Select Abnormal Heart Rate Alerts.
  5. Select High or Low.
  6. Tap the screen once to enable the alert.
From Garmin Connect:
  1. Open the Garmin Connect app.
  2. Access the menu by selecting More (bottom right).
  3. Select Garmin Devices.
  4. Select your vivosmart 4.
  5. Select Sounds & Alerts.
  6. Select Abnormal Heart Rate Alerts.
  7. Enable the Low Alert and/or High Alert.
  8. Select High Alert Threshold or Low Alert Threshold to update the value.
vívosmart 5
From the Watch:
  1. Press the button to view the menu.
  2. Select Settings gear .
  3. Select Heart With Gear .
  5. Enabled High and/or Low.
  6. Tap the touchscreen to confirm the threshold value.
  4. Select your vivosmart 5.
  5. Select Alerts.
vívosport®
  2. Select Heart.
  4. Set the heart rate threshold value.
