Using the Sleep Widget or Glance
The Sleep widget/glance will give you a basic timeline of your total sleep time and sleep phases. On select devices, it will be named " Sleep Score." Selecting the widget/glance will show you your sleep and wake times, along with a more detailed graph of your sleep phases. To see which watches are compatible with this feature, expand the drop down section below.
Compatible Watches
NOTE: If you do not see the Sleep widget or glance, make sure your software is up to date.
  • Approach® S50
  • Approach® S70 | Approach® S70 - TaylorMade® Edition
  • D2™ Mach 1 | D2™ Mach 1 Pro
  • Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition
  • Descent™ G2
  • Descent™ Mk2 | Descent™ Mk2 | Descent™ Mk2i
  • Descent™ Mk3 | Descent™ Mk3i
  • Enduro™
  • Enduro™ 2
  • Enduro™ 3
  • epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition
  • epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition
  • fēnix® 6 - Standard Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
  • fēnix® 6S - Standard Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
  • fēnix® E
  • Forerunner® 165 | Forerunner® 165 Music
  • Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music
  • Forerunner® 265 | Forerunner® 265S
  • Forerunner® 570
  • Forerunner® 745
  • Forerunner® 945 | Forerunner® 945 LTE
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
  • Forerunner® 970
  • Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition
  • Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
  • Instinct® 3 - AMOLED | Instinct® 3 - Solar
  • Instinct® 3 Tactical Edition - AMOLED | Instinct® 3 Tactical Edition - Solar
  • Instinct® Crossover Solar | Instinct® Crossover - Standard Edition | Instinct® Crossover Solar - Tactical Edition
  • Instinct® E
  • Lily® 2 | Lily® 2 Classic
  • Lily® 2 Active
  • MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
  • quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar
  • quatix® 7 - Sapphire Edition | quatix® 7 - Standard Edition | quatix® 7X - Solar Edition
  • quatix® 7 Pro
  • tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
  • tactix® 8 - AMOLED | tactix® 8 - Solar
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
  • Venu® 2 | Venu® 2S | Venu® 2 Plus
  • Venu® 3 | Venu® 3S
  • Venu® Sq 2 | Venu® Sq 2 - Music Edition
  • Venu® X1
  • vívoactive® 5
  • vívoactive® 6
  • vívomove® Luxe
  • vívomove® Sport
  • vívomove® Style
  • vívomove® Trend
Using the Sleep Widget / Glance
After a night of sleep you will be able to see a quick view of the details by accessing the Sleep widget/glance.
  1. From the watch face, navigate up through the widget/glance loop.
  2. Once you locate the Sleep widget/glance you can view your sleep time.
  3. Select the Sleep widget/glance for more details.
Adding the Sleep Widget / Glance
If you are unable to locate the Sleep Widget/Glance you may need to enable this feature. Most watches will follow the steps listed below, but for exact steps, see your owner's manual.
  1. Access the settings menu on your device.
  2. Select Widgets or Glances.
  3. Select Add.
  4. Select Sleep.
After you sync the watch with your Garmin Connect account you will be able to see a more detailed view of your sleep data.
Relaterede
