Garmin Connect: Sending More Than One Workout to a Device
Our Garmin Connect™ platform allows for workouts to be created and sent to compatible Garmin® fitness devices. Garmin Connect can send multiple workouts to devices, as long as the device accepts multiple workouts.
Adding workouts to the Calendar will allow for multiple workouts to be sent to compatible devices when they sync with Garmin Connect. For instructions, see: How to Schedule Workouts Using the Calendar in Garmin Connect.
NOTE: When naming workouts, keep in mind that most devices have a limit where they only look at the first 15 characters in the name of a workout. If you have multiple workouts where the first 15 characters are the same, the device will think they are the same workout. To work around this limitation, make sure the names vary within the first 15 characters.
