Using Course Planner on a GPSMAP 66 or 86 Series
The GPSMAP 66 and 86 series handhelds now have a Course Planner feature that allows you to easily create courses using either direct paths between points or calculated routing to follow available roads and trails.
NOTE: If you do not have Course Planner, you may need to update the software on the handheld or add Course Planner to the Main Menu. Use Garmin Express to update the software or refer to "Customizing the Main Menu" in your owner's manual if the software on the handheld is already up to date.
Creating a Course
  1. Press MENU twice to access the Main Menu.
  2. Select Course Planner.
  3. Select Create Course.
  4. Select Direct Path or Roads & Trails.
  5. Select Select First Point.
  6. Select a category.
  7. Select a point.
  8. Select Use.
  9. Select Select Next Point and repeat steps 6-8 to continue adding points to the course.
  10. Select Done to save the course.
Navigating a Saved Course
  3. Select a course from the list.
  4. Scroll to Map Tab to view the course on a map.
  5. Select Go.
