Getting Started with the Instinct Tactical
If you're setting up an Instinct Tactical for the first time, the following steps walk you through the process to help you get the most out of your new watch.
Setting up the Instinct Tactical
When powering on the  for the first time, you'll be prompted to configure your user setting and preferences on the watch. These settings can be changed at any time.
1. Power on the Instinct Tactical by holding CTRL
Click here to learn about the buttonsInstinct Tactical Buttons
2. Choose your language by scrolling through the list using UP/MENU and DOWN/ABC, press GPS to select the language
3. Pair the watch to your smartphone with the Garmin Connect App (optional)
Click here for help with Bluetooth Pairing
4. Proceed through the onscreen prompts to select your preferences and user settings
Learn More about the Instinct Tactical
The following articles will help you explore and use the many features of the Instinct Tactical.
Tactical Features
Connected Features
Customizing the Instinct Tactical
Relaterede
