Using the Trip Planner or myTrips app on a Honda Navigation System
Your Honda navigation system has the ability to create customized trips with up to 30 locations in a single trip and will allow you to edit them. This can be done using the Trip Planner or myTrips feature built into the system. Choose your vehicle below for instructions on how to use this feature.
Creating a Trip
2018 and newer Honda Accords and Odysseys
1. Touch Navigation
2. Touch Where To?
3. Touch myTrips
4. Touch Create Trip
5. Touch Add Starting Point
6. Search for the start location
7. Touch Select after touching the start location
8. Touch Add Destinations
9. Search for the next destination
10. Touch Select after touching the next destination
11. Repeat steps 8 through 10 to add additional destinations
- The final destination you enter will be the end location for the trip.
- Use the arrows on the right side of the screen to drag the destinations into the desired order
12. Press Back to return to the myTrips menu
13. Touch Go to begin the trip
The trip will automatically be named based on the ending location. See Editing a Trip below for instructions on changing the trip name.
2019 and newer Honda Pilots, Insights, and Passports
1. Touch Navigation
2. Touch Where To?
3. Touch myTrips
All Other Models
1. Touch Navigation
2. Touch Apps
3. Touch Trip Planner
4. Touch New Trip
5. Touch Select Start Location
8. Touch + (in the upper left corner)
9. Search for the end location
10. Touch Select after touching the end location
11. Touch + (in the upper left corner)
12. Search for the next destination in the trip
13. Touch Select after touching the next destination
14. Repeat steps 11 through 13 to continue adding destinations
15. Touch Next after selecting all destinations
16. Enter a name for the trip
17. Touch Done
18. Touch Go to begin the trip or Back to return to the Trip Planner menu
Editing a Trip:
1. Touch Navigation
2. Touch Where To?
3. Touch myTrips
4. Touch the trip you wish to edit
5. Touch Edit Destinations or Touch Trip Settings
- Touching Edit Destinations will allow the order of the destinations to be changed, destinations to be added, and destinations to be deleted.
Touching Trip Settings Provides the Following Options:
Trip Name: This option will allow the trip name to be changed or customized.
Optimize Order: This option will optimize the trip into the most efficient order based on your navigation settings. For the optimize feature to work, the trip must have at least 4 destinations.
Calculation Mode: This option allows the calculation mode used for the trip to be changed. See How the Routing Preferences Work on a Honda Navigation System for information on the different calculation modes.
Avoidances: This option will display a list of available avoidances for the trip. See Navigational Avoidances on a Honda Navigation System for information on the avoidance options.
1. Touch Navigation
2. Touch Where To?
3. Touch myTrips
All Other Models
1. Touch Navigation
2. Touch Apps
5. Touch the menu bars (3 lines) in the upper left corner
The options for editing the trip will now appear on the screen.
From the Edit Menu you Can:
Edit Destinations: This option allows the order of the destinations to be changed, destinations to be added, and destinations to be deleted.
Delete Trip: This option will permanently delete the selected trip from the system. After selecting this option, a final prompt confirming the deletion will appear.
Rename Trip: This option allows the trip name to be edited from the original name entered.
Optimize Trip: This option will optimize the trip into the most efficient order based on your navigation settings. For the optimize feature to work, the trip must have at least 4 destinations.
