Pairing a zumo 500 or 550 with a Bluetooth phone or headset
You can use your zumo with your cell phone, headset, and/or helmet by pairing them. Before you begin, set your Bluetooth phone or headset to Find Me/Discoverable mode. If you are not sure how to do this, refer to the owner's manual or documentation that came with the device.
In order to connect to the zumo, the cell phone must be running either Android 2.1 and newer or an iPhone 4S and newer running iOS 6.0 and newer. If connecting a headset, it must support the hands-free profile and use Bluetooth version 1.1 or higher. Note: These are general guidelines, and do not guarantee compatibility.
Bluetooth should automatically be enabled on your device, if it is not use the following steps to enable Bluetooth:
- Touch Settings (Wrench icon)
- Touch Bluetooth
- Touch box next to Bluetooth
- Touch Enabled
- Touch OK
The Bluetooth will now be enabled on your device.
To pair and connect your phone with your device:
- Touch Bluetooth
- Touch the Add button next to Connect Phone
- Touch OK on the message that prompts you to set your Bluetooth Device to Find Me or Discoverable mode
- Touch the name of the desired phone from the list
- Touch OK
- Enter the passkey displayed, if prompted
- You will receive the following message on the zumo, "The zumo must be in a powered mount or be connected to a Bluetooth headset to hear audio"
- Touch OK
To pair and connect your phone and headset or helmet with your device:
- Touch Bluetooth
- Touch the Add button next to Connect Headset
- Touch the name of the desired headset from the list
- Touch OK
- Touch OK
The zumo should now be paired with both the phone and headset or helmet.
