Dash Cam Saved Files Missing
The Dash Cam will automatically protect (save) files if an event or accident is detected. You can also manually save video files, as desired.
If any of these saved or protected files are missing from the Dash Cam's memory card, the Protected Video Overwrite setting may be enabled.
To disable this setting on the Dash Cam:
  1. Press the button under the Settings icon
  2. Press the button under the up or down arrows until Protected Video Overwrite is highlighted
  3. Press the button under OK to remove the check mark
Protected files will no longer be overwritten.
