Install or Install All installs updates to software and any maps that are currently installed to your device.
View Details shows details on the specific updates (software, GPS, or map).
Map Details shows what maps are currently installed to your device. If you click on it and then Options, this will allow you to reinstall any maps that are already up to date.
Manage Maps allows you to add or remove maps from the device.
Managing Maps on Garmin Devices With Garmin Express
The Manage Maps feature allows you to install additional map regions on select Garmin® watches and Edge® cycling computers. It also allows you to view, update, remove, or add maps. This feature is available for the following devices:
D2 Mach 1
Edge 1030 Plus
Edge 540 | Edge 540 Solar
Edge 840 | Edge 840 Solar
Edge 1040 | Edge 1040 Solar
Edge Explore 2
Enduro 2
epix (Gen 2) | epix (Gen 2) Porsche Edition | epix (Gen 2) Sapphire
- epix Pro (Gen 2) watches
fēnix 7 Standard Edition and all other watches in the fēnix 7 series.
- fēnix 7 Pro watches
Forerunner 955 | Forerunner 955 Solar
Forerunner 965
MARQ Adventurer (Gen 2)
MARQ Athlete (Gen 2)
MARQ Aviator (Gen 2)
MARQ Captain (Gen 2)
MARQ Golfer (Gen 2)
quatix 7 Standard Edition
quatix 7 Sapphire Edition
quatix 7 Solar Edition
tactix 7 Standard Edition
tactix 7 Pro Edition
tactix Pro Ballistics Editions
Managing Maps With Garmin Express™ Software
If this is your first time using a computer with your device, you will need to download and install Garmin Express. For information on downloading and installing Garmin Express, see - How Do I Install Garmin Express?.
Connect your device to the computer with the Garmin branded USB charging cable.
Launch Garmin Express.
Select your device.
If this is your first time using Garmin Express, see - Adding and Removing Devices in Garmin Express.
Garmin Express will then display available updates. If it says you are up to date, then the software and maps currently installed to your device are on the most current version(s).
NOTE: Ensure that your computer has enough disk space to download and temporarily store updates and/or map files.
Select Manage Maps to add or remove maps from your device.
Check or uncheck maps to add or remove them from your device.
Select Apply Changes.
Review and accept any prompts for Terms and Conditions or Important Notes.
Once Garmin Express finishes applying the changes, disconnect your watch from the computer.
