Navigating to a Waypoint on an eTrex 10/20/20x/22x/30/30x/32x
The eTrex® 10, 20, 20x, 22x, 30, 30x, and 32x outdoor handhelds can navigate to a waypoint from the devices current location.1
Navigating to a Waypoint Using Where To?
  1. Select Where To?.
  2. Select Waypoints.
  3. Select a waypoint from the list.
    • The keyboard may appear to cover the list of waypoints if sorting is set to Alphabetical. Press Back in order to hide the keyboard, then press Menu and select Sort if you wish to change the sorting method.
  4. Select Go
Navigating to a Waypoint Using Waypoint Manager
  1. Select Waypoint Manager
  2. Select a waypoint from the list.
  3. Select Go
1 The eTrex 10 handheld cannot route on roads and will only show direct (straight line) routing. The eTrex 22x and 32x support turn-by-turn routing and come pre-loaded with routable TopoActive mapping. Other eTrex models support turn-by-turn routing, but only if a routable map has been added to the device.
Relaterede
